Question about HP LaserJet 3055 All-In-One Printer
Documents are appearing faint when scanned
I hope this is an easy fix and ive missed something silly.
When i scan a document to a local PC it scans very faintly, and then obviously prints out very faintly when i print it. I am trying to scan a letter which has a logo at the top and a signature in biro at the bottom. The thing is this worked fine before the PC was re-loaded.
After the PC was reloaded the drivers and the scanner software was installed the same as the first time round, when it did actually work. These have been installed from the original CD.
I have tried to adjust the brightness options to darker and the contrast but this doesnt make any difference, i have selected colour instead of black & White because of the colour logo on the letter but still doesnt change.
I have tried this using the HP provided scanning software changing the settings and also using Windows scanner and camera software but still same problem.
I tried changing the settings on the actually machine but it reverts back after i change them and doesnt save for me to try and scan again.
It is quite a big problem because letters need to be scanned into the PC after being signed and then they are emailed across the continent.
Any help will be appreciated.
Thanks
  • computersuck Oct 06, 2008
    Hiya
    Thanks for this. The bulb idea sounded like the solution to me but I have just done a copy of the document using the flatbed and it printed out fine so I am still baffled. When i scan from the flat bed it is still really faint. I have tried changing the resolution on the scanner side of things but this doesnt seem to have an affect on the quality of the scan at all.
    Any other ides?
  • 659 Answers
Ok this sounds like a fun one to solve I like it. so we are gonna try a bunch of stuff here so we can get you going and working again in no time. I hope. haha
ok first off lets make sure that the scanner bed is completely clean of anything just nice clean glass. now if you check and see if the scanner bulb is doing ok how do we do this we are going to do a atest scan and make sure that the bulb is still really bright
by the sounds of it to me the bulb might be on its way out the door if it has had alot of use it can go in a short period of time.
next will be a test to see if the copy function will print the document as it is on the scanner bed, this will tell us if its the software or the hardware if you make a copy and it is still light in color then its hardware make sure your ink is ok as well cause that could pose a problem in the testing of this as well
I will tak a look over the manual and see what I can dig up but if you could try those things so that we can eliminate the following and figure out where to go next.
will talk with you soon.
Posted on Oct 02, 2008
  • Wesley Gardner
    Wesley Gardner Oct 02, 2008
    the only other thing i would say would be to check you scanners scan resolution see if its set too low it might have to be put up a bit as well this could also change the quality of the scan.
Issue with scanning documents to PDF however no issues with printing documents
from the sounds of this you have dirt or something on the scanning lenses. you need to check where the document you are scanning is loading it is carried across a lens that creates the image, if this is dirty you will get your symptoms coming out. if you lift the cover where the document is feed in you can clean this lens with some glass cleaner and a soft cloth. if all is printing ok you will waste ink by carrying out cleaning and alignment programs so save your ink and check the lenses for scanned doc. Hope this helps.Andy
Mar 11, 2015 | Office Equipment & Supplies
Documents disappear after scanning via pdf
Check the complete queue on your printer. Maybe there it has an error
Mar 22, 2013 | Office Equipment & Supplies
Scanned documents appear too light (faint). is there an adjustable feature to darken the tone of a scanned document?
The scanner reader is probably bad. Canon calls it a Contact Image Sensor FK2-1377-00
This is moderately hard to install because it is under the glass.
Whit www.iteminconline.com
Sep 15, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
When I scan my documents there's a black line that appears down the pages. How do I fix it?
This is usually caused by something on the image scanner glass. Check out this page.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, if so please rate our solution.
BuddyMc
Mar 22, 2011 | Office Equipment & Supplies
How do i scan something on my pc/
Just use the Scanners & Cameras function in the control panel. Double click this icon to start commencing the scan process. Just make sure the document you are about to scan is already placed in the printer scan bed.
There are also printers that has scan button on their printer. you can use this if you have. Press the Scan button. Wait on your pc and save the documents.
I hope you got the idea.
Please rate this answer with 4 thumbs up.
Thanks
Sep 12, 2010 | Office Equipment & Supplies
HP OJ 6500 with windows7..Scan button on scanner is not working.
The reason that you are unable to scan through the printer is, you are missing HP full feature software and driver.
Please download and install it from the below link
DOWNLOAD
Regards
Rizwan
Feb 13, 2010 | HP Officejet 6500 Wireless All-in-One...
Canon mx320 does not scan
make sure that scan driver is completely installed in your computer.
To scan a documents in jpeg format, use the scanner icon in the control panel of your system. Insert your document in scanner bed then double click the scanners & cameras icon in the Control Panel.
To scan a documents and save in pdf format. just press the Scan button in the printer and save the documents in your computer once the scan window appear.
Oct 20, 2009 | Canon PIXMA MX310 All-In-One Printer
I place a document on the
When you scan something, the printer makes it's own folder that goes into My Documents. It will be in My Documents or My Pictures in it's own folder called Scans. Hope this helps. Cheers.
Oct 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How do I scan and e-mail pdf documents from the MP730?
Scanners scan a document in picture format(JPEG) dot per dot. Their are complete programs out ther that will scan a document and turn it into a text fine. They are far more expensive that just copy a picture of some words on a page, Typical scanner function. I hope I have explained it well.
Feb 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
HP LaserJet 3055 All-In-One Printer Logo
949 people viewed this question
Seeker5211
Seeker5211
