Question about Kenmore 24032\24036 Top Load Washer
Kenmore 110.24422300 Top Loader Washing Machine
When I set the dial to wash, the tub fills with water but the motor never comes on once it if filled. No washing, no spinning at all.
  • jab4nfl Oct 12, 2008
    I have a Kenmore 70 series. It leaks from the bottom and the water fills up and starts flooding. It doesnt seemed to go into wash. Any suggestions?
  • transformerr May 03, 2009
    I have the same problem, same model (110.24422300). Filled with water, but won't do anything else. Doesn't agitate, spin, drain, nothing.
    I'm going to start by checking the lid switch as I hear it's a likely culprit. Any other suggestions would be appreciated.
How to get top control panel to flip up?
Posted on Oct 06, 2012
    Novelist:
    Champion:
  • 261 Answers
We have one of two situations happening here. Either your timer is going or the motor is blown. The other thing is to put the machine into spin and see if it drains, let me know!
Posted on Oct 08, 2008
My Kenmore top load washing machine is stuck in
sounds like ur pump has gone out totally and the controller is bad cause its not filling the tub or is it if it is and just wont pump it out u have a bad pump
Feb 25, 2010 | Dryers
Our washing machine will not fill cold water. the
You may have a defective cold water solenoid on the water inlet valve. There is a separate solenoid for hot and for cold. So, if you've confirmed the inlet screens are clear, more than likely you will need to replace the valve. If this is a Kenmore top loader, the following link explains how to replace a water inlet valve:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
This is a very simple and inexpensive repair. The average cost is about $30-$35. A replacement can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you need further assistance, please post back with your complete model number (located under the wash lid along the tub rim), so that I may be able to provide you with better service. I hope this helps you.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
2 year old top loader Kenmore fills, washes, doesn't drain & does
check yor lid switch,,its a little switch on right side of cabnit..listen for a click,,your unit doesnt have a belt it has coupling
Dec 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Top Loader
try different temp settings be sure screens in inlet valve end of hoses are clean and taps on all the way if you gave water to washer and still none coming in suspect bad fill valve
Sep 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
590 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
