Question about Olympus FE-190 Digital Camera
Unable to take photographs screen keeps saying card cover open but this is not the case
Http://www.fixya.com/support/t142428-olympus_fe_130
on the page of the above link you see a photo of the solution with the copper wire.
Posted on Mar 04, 2009
How do i read the display
Hi
I have had a look at the manual, which can be seen here:-
http://www.naturecounters.com/catalog/birdcams_userguide_lo.pdf
and downloaded if required.
I also assume that the screen you quote 0000/2009 from looks like this: 25298386-zaroub1mziznni4k1xdwqerx-3-0.jpg and although not clearly explained in the manual (at least during my quick perusal) my previous experience of other cameras makes me think that this is related to the photographs taken by the camera and stored on the SD card, and the number of photographs can still be stored on the SD card according to the resolution the camera has been set to.
In your case I would say you had no photos on your SD card with space available for 2,009 more at the resolution set.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Wingscapes WSCA02 Digital Camera
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
Help with my Fe-340 Olympus Camera?
I have olympus digital camera. from some time when I take photograph THe screen remains black & if the picture is shoot ,it is also black
Jun 26, 2009 | Olympus FE-340 Digital Camera
Screen keeps going off and on
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Feb 21, 2009 | Acer Aspire 9300 Notebook
Unable to download pictures from computer to digital frame
The primary software is going to extract all the images, put only the images you want on the card, then insert into your picture photo frame.
Jan 08, 2009 | SmartParts SPX8 Digital Picture Frame
Direct image feed to digital Frame?
I just did a fast lookup and heres one frame
http://www.onecall.com/ProductDetails.aspx?id=89172
You can take the memory card with the pictures out from your camera and insert it into the picture frame and instantly view all the pictures from the card on the picture frame.
Nov 18, 2008 | PANDIGITAL 15-inch Digital Picture Frame...
Canon digital IXUS 60. Lens does not move in and out. Camera turns on but nothing happens. Unable to take photographs. Error message:- Lens error restart camera. Restarting camera does not resolve problem
I'm guessing that the lens is stuck. Either the cover refuses to open because something is wedged in or a mechanical malfunction. The camera won't work if the lens does not come out a bit. Take a look at the lens and examine why the cover doesn't open up. If it is a mechanical malfunction (meaning internal problem), might as well have it fixed. Be careful and keep your fingers off the lens. You may touch the cover but hands off the lens. Hope this helps.
Jul 17, 2008 | Cameras
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
Faulty Lens?
Dear Swetnam
This is a internal circuit problem/defect and cannot be done on our own, so u should take it to SONY service centre. Avoid keeping the camera near hot temperatures zone. Sony is not tolerant to many physical factors.
Feb 07, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Olympus FE-190 Digital Camera Logo
159 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
