I have a LG 32LX2R-ZE flat screen LCD TV, We've recently had a power cut and the TV doesn't seem to work, Cable is okay but there is no power getting to the TV. I havn't got the manual and i've heard that it has a built-in fuse, Is this true and could this be the problem?
  • Leevis Apr 13, 2009
    Exactly the same TV and power cut problem
  • Leevis May 19, 2009
    Just bumping this one up a bit, anyone got a solution for this one. Not much about on the internet about his problem but i did read somewhere that this TV has an internal fuse. If this is the case i could just replace this if i new where it was
I used to be a TV engineer many years ago, and I do not profess to know much about flat screen TV's.
I have just been asked to look at one of these which has suffered the same fate as yours.
It does have an internal fuse, but it is not a "normal" household fuse, it is a component fuse and you will need to be able to solder and de-solder to be able to fit one.
That said, the TV I have here, the fuse is OK, if I disconnect the PSU from the main board, the standby +5V recovers, suggesting the PSU is operational. Connect it back up and it drops, something is shorting out the +5v, which is why it will not switch on.
Without a diagram, this has become very frustrating, and Ithink I am going to have to give up,
Sorry it's not good news people!
Cheers
Shaun
Posted on Nov 01, 2010
  • melhadfield Mar 15, 2011
    Hi
    I have the same problem, could you tell me which pins on which connector to check the 5v standby please?
    Cheers
    Mel
    Hi Shaun
    I have the same problem, could you let me know which pins on which connector you checked for the 5v standby?
    Cheers
    Mel
My LG 37LC2D picture suddenly goes black and then if I bang on the corner of the set sometimes the picture will return. What is wrong with my TV?
could be the power supply card(s) is unseated..open it up if you dare and re-seat and/or maybe remove and clean the card edge connector contacts with an eraser
May 27, 2012 | LG 37LC2D Television
We recently bought a Samsung 500 Series 46" LCD
make sure you have the aspect ratio set at 16:9.
Mar 23, 2011 | Samsung Televison & Video
We have an LG 32LX2R-ZE. We have no sound, but the picture (Virgin Cable) connection is fine as is our Internet. I've checked all the leads and, no, neither the TV or the Virgin box are on mute!. Any...
I had the same problem and after buying loads of different cables came to the conclusion that the HDMI input on the TV was at fault. Bit of a sledgehammer to crack a nut but I upgraded my home cinema amp to one that had HDMI in/out and now I put the sound through that and use the TV as a panel with volume turned to zero.
Jan 13, 2011 | LG Televison & Video
No power. nothing
U can tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board to fix it ur self.Buy it ur self, to do it ur self.The power supply board should cost $120 to $140 plus shipping.The shop should cost $300 to $400 for power supply board part and labors.
Mar 02, 2010 | LG 26LX2R 26 in. HD-Ready LCD TV
LG 32LX2R TV - AV2 in B&W
factory reset for the PS3.
turn the power off on the PS3 what I want you to do now is turn the power back on whilest holding the button down for approx 5 seconds this should then bleep. Thats it reset.
Hope this helps you out.
Little Dish Fitter.
Oct 07, 2009 | LG 32LX1 32 in. HD-Ready LCD Television
My ViewSonic LCD tv works for a while then the picture cuts to black. audio is still okay. rest it and it comes back for a spell
Seems to me like you have a backlight problem, its the inverter board which powers the backlights that brighten up the screen so you can see the image, sometimes the capacitors on these boards fail due to the immence heat, in some models they are separate or on the same board as the power supply board.
hope this helps
jonno
Aug 12, 2009 | ViewSonic N3290w 32 in. LCD TV
Picture outside of screen limits
I have Time Warner Cable and just FIXED this problem. On the cable box remote, there is a button with the word "Aspect" on it. On my particular remote, this is the "#" button (pound symbol) and by pressing that button, it gives you options of "Zoom 1", "Zoom 2", "Stretch" and "Normal". By setting it to "Normal", it completely solved the problem. Oh and by the way, my t.v. is the LG 47" flat screen LCD. Hope this helps the other frustrated folks out there.
------Dave
Jun 08, 2009 | LG 42LG50 42 in. LCD HDTV
Power supply unit, TV cuts off after 20 seconds
i would recommend ebay, they usually have lots of parts for lcd tvs
Jan 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Having problems with my new HD TV (LG 32LX2R)
Hello, please call the dealer ASAP. This should be an in warranty case. Best regards, Arpi
Jun 24, 2007 | LG 32LX1 32 in. HD-Ready LCD Television
Televison & Video Logo
1,823 people viewed this question
Top Televison & Video Experts
Electro Med Services...
