Question about Kenmore 73952 Gas Dryer
Kenmore elite doesnt heat up glow bar comes on but cant smell gas gas line is on
  • jimmy3299 Oct 02, 2008
    i fixed it at first i thought changing the thermo fuse but found out if it was defective nothing would work so it was recomended to change coils it was an easy fix cost abit over 50 bucks but its working now thank you
  • 5,911 Answers
Just because the glow bar igniter comes on, does not mean it good. They typically get weak with age and fail to draw sufficient enough current to open the gas safety valves. That is why you don't smell any gas. This is a designed safety feature of the burner that prevents free flowing gas from escaping before ignition. Otherwise, gas would fill the cabinet and then "phoooooom", a huge flash or explosion when the trapped gas finally ignited. I would recommend you read the following link about glow bar igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know this link is for a gas range, but the igniter types and the principle of operation is the same. If you've had this dryer for a while, I suspect you need a new igniter. Replacements can be ordered on line at searspartsdirect.com. Just type in your complete model number and look under the heading for burner assembly parts. Another cause of failed ignition would be the gas valve coils. There are generally two of them on the burner. One is the main coil, while the other is a pilot position coil. When they go bad, however, they typically make a clattering noise. Let me know if you have similar symptoms.
I hope you find this information helpful. Let me know if you have further questions.
Posted on Oct 02, 2008
  • Jeff Rockwell
    Jeff Rockwell Oct 03, 2008
    "Thanks for Trying", though? I wish you would have just retracted your question, or left the coments unrated. Sorry, I could not have helped you. I'm glad you were able to resolve this on your own.
For a kenmore elite gas dryer #3979964 that is not heating where do we check what is going on?
That is not a full model number, check again and update. It could be a fuse, gas valve, thermister or glow bar.
Sep 27, 2015 | Kenmore Dryers
He3 gas dryer not heating
thee a lot compenents in the heat circuit it could be any one of them , starting with the thermal fuse,thermostat, safety valve ,glow bar, and flame sensor
Apr 30, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
I have a kenmore elite dryer model # 11070952990 that will not heat up, I replace the glow bar ignitor, I don't know what i'm missing.
Check the thermal fuse. You can temporarily bypass it by hooking its two wires together then see if it heats.
Sep 24, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
Jul 14, 2011 | Magic Chef Ovens
I replaced the igniter (glow bar)on our Kenmore
IF THE UNIT IS 14 YEARS OLD BE CAREFUL THE GAS VALVE MAY BE GETTING TO THE POINT WHERE IT IS NOT SHUTTING OFF AS QUICK AS IT USE TOO, YES THIS WOULD CONCERN ME ,YOU DON'T KNOW IF ONES OF THESE TIMES THE GAS VALVE MAY NOT SHUT AND GAS BUILD UP COULD BE POSSIBLE ,NOT A GOOD THING. PLEASE BE CAREFUL
Aug 31, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
No heat to our gas frigidaire dryer
Make sure the gas valve is opening, you'll smell gas. Second, check if the glow bar comes on or, if the thermal couple is lined up to the igniter.
Jun 30, 2009 | Frigidaire GLGQ2152ES Gas Dryer
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Aug 10, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
