Ignition Module Troubleshooting White Rodgers 50A52-120
  • 99 Answers
This is OEM special part you need to contact Goodman Manufacturing. Website Phone 866.304.0137
Posted on Jul 07, 2010
Hi @ radom_4421@yahoo.com
1. blower keeps on running
2. try's for 2 or 3 times then shuts down.
3. sometimes works good for a few days no problems?
4. white roger #50A50 control
thanks
Posted on Nov 23, 2008
  • RICH Nov 23, 2008
    IT'S A LUXAIRE FURANCE
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
Wiring diagram white rodgers 1F82-51
Hi. This is Aaron Moratalla from White Rodgers. If you are looking for the wiring diagram of 1F82-51 see it in page 3 of the manual using link below:
http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-5650rev_A.pdf
If you need more help please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
I need wiring diagram for thermostat white rodgers
Hi. This is Aaron Moratalla from White Rodgers. See this link for the copy of manual. http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6841.pdf
Wiring connections are on page 7. If you need more help don't hesitate to call Tech Support at 800-284-2925. Thank you for choosing White Rodgers.
Jan 17, 2013 | White Rodgers White-Rodgers 1F85RF-275...
Trouble shooting my white-rodgers manual thermostat 1f56-444
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To better assist in troubleshooting your thermostat contact us directly at 18002842925.
Oct 14, 2012 | Home Security
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
I've got no heat. Going by the control module, white rodgers p/n 50E47-847, I'm getting a lockout signal and ign. cycles exceed. I shot across the Ignitor, to check resistence and it read > 1.000 M and...
Try turning off the thermostat, and the curcuit breaker for the Furnance isside the Breaker box, wait about 15-20 minutes and turn the breaker back on, this should reset the thermostat and clear the lock-out, and you should be able to obtain heat, if the Furnance is displaying a code you will have to find out the meaning of the code and do the necessary steps on the furnance cover under troubleshooting.
Dec 12, 2009 | Heating & Cooling
White Rodgers main gas valve operation.
pleas follow the troubleshooting page 9, 10 and 11
Dec 10, 2009 | Heating & Cooling
Newly installed white-rodgers zone valve works for a while then eventually moves to manual (or open) on its own. Suggestions on how to keep valve in a closed position? Chris in Alaska
This problem has to be in the way the valve was wired. Wrong zone valve-Normally open instead of normally closed-power interuption causing valve to open. Faulty T-stat/ Most likely wired incorrectly.
Sep 13, 2009 | Plumbing
Troubleshooting techniques for natural gas spark ignition modules
the white-rodgers site has spark ignition modules
Jan 19, 2008 | Heating & Cooling
Heating & Cooling Logo
1,671 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
