I have a Sony RDR-HX715 DVD/HDD Recorder. I have several tracks that are over 3 hours in length. When I try to dub them over to DVD, the machine shuts itself off and stops the dub process. I have tried both DVD R and DVD-R discs. I have used the Auto Mode option to set the file size to one that is small enough to fit on a DVD and that makes no difference. I have tried powering down and unplugging for a period of time to release any static electricity that might have built up and/or to cool down and reset, but no luck. Any idea what might be causing the problem?
SOURCE: we have a sony rdr-hxd
We have a wide screen tv in 16.9 screen mode. We have found we can only dub HDD-DVD in screen mode 4.3. Problem solved.
Posted on Jul 07, 2008
SOURCE: Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Posted on Jun 16, 2009
SOURCE: locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
4 Let up, press RETURN, all done!
Posted on Oct 01, 2009
SOURCE: LG DVD/VCR Recorder Combo RC195 will not finalize DVD after dubbing
It seems that it won't finalise because the disc is full. If you stop before the "Disk is Full" warning at two hours you should be able finalise, but, the disk still won't be recognised. DVD+R seems to work OK.
Personally with LG, Life's NOT Good.
Posted on Dec 13, 2009
SOURCE: Dubbing from DVD to HDD
You did get this from me but, if you are trying to dub a protected dvd, the dub option will be greyed out. Non-elegant solution: use another device to play the dvd and run it as input into the DVDR. You won't have the menu items but you will have the video.
Posted on Apr 25, 2010
How to replace hdd on Sony RDR-HXD860 DVD Recorder/HDD Recorder?
The HDD must order from Sony It can not replace with the computer HDD.
May 04, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
HDD error
I have a SONY RDR HX-750 video recorder, that as of late has frequent "dub error" incidents...this unit has had a lot of use since purchased. It has served me very well until now. I have erased several recordings (many hours), and optimised the hard drive in an effort to correct the no avail. The problem persists. I can therefore, ownly deduct that the dvd drive is very "dirty", and needs to be "cleaned" (HOW CAN I DO THIS?)...or there is something wrong with the hard drive? Can you please help? Many thanks for any help and your time and consideration. Have a very good day!
Feb 20, 2010 | Sony RDR-HX900 DVD Recorder
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Sony hxd890=rec from hdd to dvd
I had the same problem but changed the recording mode to SP. I used a DVD-RW to high speed dub a two hour film and a documentary about a holiday island.
Both dubs were perfect.
Dec 23, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sounds like the DVD is not finalizing or not doing so properly. Check your setup options...
Mar 30, 2008 | Sony RDR-VX555
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
