Question about Zebra LP 2844 Thermal Printer
Calibrating Continuous label Zebra LP-2844
Hi I do have aproblem with one Zebra LP-2844 to setting up the size of the continuous label. The first label it ok. and the next coming out side down.
can you, please, help me with this.
Thank,
Miguel
  • micrologix Jan 10, 2009
    When i Print from 1st class mail it prints fine,but when i change the lable to Priority Mail the Bar Code comes to the next page whats wrong with this?
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
SOURCE: label printer
Try reseting the auto gap detection.
http://www.fixya.com/support/p257130-zebra_lp_2844_thermal_printer/manual-19245/page-15
Posted on Mar 30, 2008
  • 6 Answers
SOURCE: Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Posted on Sep 25, 2008
SOURCE: prints out 2 labels at once
I've seen this be due to dirty sensor or misconfigured media setting.  Clean the sensor in the middle of the edge on the inside and outside of the printer, then if still having trouble - Inside the printer it should tell you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pages print some info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
You have just made it reconfigure media, and it may know when to stop feeding now.
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Posted on Apr 10, 2009
Label splits
because if label lengh is ex. 20mm and you set up label print area as 21mm, it will over the size and it will skip the next one. the print area shoul be less than the label length. please verify software or driver.
Jan 22, 2014 | Zebra LP 2844 Thermal Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
I use direct thermal paper with a black mark at
Compare the 2 rolls, Pay close attention to the position ans size of the black mark. The black mark sensor in the zebra 2844 is not (where you would expect it to be) in the centre of the label. It is about 10mm to the right,
Try calibrating the printer to your labels.
Check my other solutions to see how to perform a manual calibration.
Jul 29, 2009 | Zebra LP 2844 Thermal Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 Thermal Printer Logo
537 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
