Question about Dell 3010cn Laser Printer
Cyan toner does not rotate to front to be change
The cyan toner low message has been showing for 5 months. I have the toner and need to replace the cartride, but the toner cylinder will not rotate to the front. Only the blue cartridge is in front, although it makes sounds like it is moving to the front.
  • 49 Answers
Um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Posted on Feb 27, 2009
Trouble code c2551 on konina minolta bizhub c454e
c2551 come when Cyan low toner in Cyan Developing Unit.
Try to reset by opening and closing front door.
and check toner supply-hopper
if not still ok then replace Cyan Developing Unit.
Nov 30, 2016 | Konica Minolta bizhub Office Equipment &...
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
Replaced cyan toner and message still says replace cyan toner
1. Turn off the printer for 2 minutes.
2. Open the front door.
3. Remove the Imaging Unit. (Pull the green handle towards you)
4. Remove the Waste Toner Tank. (It is a L shaped thing with a handle) (It is near the cyan toner, on the left side)
5. Empty the tank carefully in a bag. If you want, clean it with water and you MUST put it out in the sun to dry.
6. After drying, put it back in and try again.
If it doesn't work, then just remove the cyan toner and clean the place where it was.
Mar 03, 2011 | Samsung CLX 3160fn All-In-One Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Toner needs black toner how do i replace just the black toner
You shoulh have a button to rotate the carousel, or unplug the power cord and try again.
Mar 03, 2009 | Epson Aculaser C1100 Printer
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
How to remove the toner cartridges
Close the cover to the machine and make sure you aren't getting any other error messages other than the toner. When the printer is at the ready state press the rotate toner button. You should hear the printer rotate the toner and then the light over the cyan cartridge will come on. Keep pressing the rotate toner button until you get to the color you want to replace. Open the top cover and front door where the KM logo is. You should see the cyan cartridge in place. Pull the cyan tab back toward you. The front part of the toner should release. Now pull the tab and the toner straight up and out of the printer. If you are having problems getting the toner out it is probably not in the correct position. There is a slot on either side of the printer that he back end of the toner cartridge needs to be in before the toner will come out.
Jul 10, 2008 | Minolta magicolor 2400W Laser Printer
K toner low
C - is for Cyan
M - is for Magenta
Y - is for Yellow
K - is for BlacK
Jan 25, 2008 | Epson Aculaser C1100 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Dell 3010cn Laser Printer Logo
224 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
