Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
Can't connect a Dlink 1260 Print server through my Linksys wireless G router
Connection problem
  • 186 Answers
Make sure the IP address on the dlink is in the subnet 192.168.1.0 by default it is 192.168.0.0 and linksys is 192.168.1.0
Posted on Oct 02, 2008
    Sergeant:
  • 268 Answers
A couple of things to check for:
  • If the wireless network is encrypted on your router verify that you have the right encryption key programmed on the print server
  • You are connecting to the corret router (Verify the SSID of the network - SSID being the networks name)
  • Make sure you are in an acceptable range , not 500 feet away from the router
  • Verify that the print server has a connection to the printers connected to it
  • Try rebooting all of the equipment (router , server, printers)
3 Suggested Answers
mspcrepair
  • 169 Answers
SOURCE: Connecting this print server
Without knowing more information, I can't give you exact instructions...however, in order to make the print server truly functional, it needs a dedicated IP address. Look through the settings on the print server interface (GUI) and see if you can assign it a local IP address (192.168.xxx.xxx, depending on your LAN setup).
Once you give it a dedicated IP address, you should be able to route print jobs through it.
Hope this helps - remember to rate :)
betz73
  • 298 Answers
try unplugging both and then plug in the router,let it reboot, then plug in the other and let them find each other. if that doesn't work let me know.
Desktop prints fine but laptop will not print going through dlink 1260 print server either wired or wireless. I should say I have a linksys router that my desktop is hardwired to, but the Dlink server is...
as no one has answered this I will give it a go .
Check or download the latest printer driver for whatever operating system the laptop is running.
Could be a dhcp server clash from the wi fi print server and the link sys router . Check there are two DCHP servers and if there are deactivate on and use the other .
check the ip addresses in use on the laptop and on the desktop and the printer. make sure subnet mask are all the same but ip addresses are unique but within the network range. eg 198.168.0.2 - 198.168.0.254 and subnet mask 255.255.255.0
or 10.0.0.2 - 10.0.0.254
check the ip address for print server is different to the ip address for the router and make sure DCHP range does not clash with router assigned ip addresses .
Dec 26, 2017 | Toshiba Satellite A205-S5831 Notebook
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DLink DPR 1260 lost connection
Are the small printer icons lit up on the face of the PServer? Mine has recently started losing connectivity and simply unplugging the power and plugging it back in restores full function. Still looking for the reason it just started doing it though..
Mar 17, 2009 | D-Link Computers & Internet
Hi!!! How do I set up wireless printing? I have an HP1022 printer...
You should have your DSR 1260 connected via cable to your router. Open a browser. Go to http://dlink-xxxxx (xxxx=last 6 digits of your 1260's MAC address) or http://192.168.0.10. The DSR 1260 web config screen will open. Click on the Setup tab (top row). Then click on Wireless Setting on the left hand column menu. Select settings based on your router's setting, Typically: Wireless Setting: On; Network Name: choose from drop down, if not there, type your router name in; Wireless Mode: Infrastructure; SuperG Mode: same as your router; Security: same as your router. Then Save.
Remove the cable connection of your 1260 and your router. Then go to Status in the web config. Click on Wireless. It should now show your router details. That's it.
Jan 24, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Sep 28, 2008 | D-Link DPR1260 Rangebooster G...
Router and New Print Server Not Talking?
what hardware version and firmware is on router.you might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR 1260 will not work at all
I had the same problem earlier. Forget that I had MAC address filters setup. You might need to add your printer server's MAC. Then it should work. Mine did. Good luck
Nov 04, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Connect d-link print server with linksys router
you might need to set the Gateway on the router to match your ip on the print server.
Oct 07, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
953 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
