Question about Dryers
I HAVE DRYER GE MOD #DWSR488EB2WW SER#ZG743601A ***HAVE GRINDING NOISE. RELPACED THE BEARING IN THE BACK. BELT SEEMS OK. PUT BACK TOGETHER NOISE CONTINUED. THE NOISE HAS A SLIGHT GRIND/SCRAPE IN ONLY PART OF THE 360 DEGREE TURN. I CAN TURN IF OFF & PHYSICALLY SPIN THE INSIDE OF THE DRYER BY HAND. IT IS SILENT FOR ABOUT 350 OF THE 360 DEGREES OF ROTATION. THE OTHER 10 DEGREES HAS A RUB,SCRATCHY SOUND WHICH DEVELOPS INTO A LOUDER WAIL WHEN TURNED ON
  • 1,543 Answers
The most likely cause is the front drum supports. There are 3 or 4 teflon strips (about a half inch wide and 2 inches long) on the top of the front panel that the dryer drum glides on. When these wear down, the drum can scrape on the plastic that holds them or on the metal frame around the door frame. Another possibility is if the drum touches the dryer exhaust vent pipe, most often only if the dryer is vented out the bottom of the dryer and the vent pipe has shifted up just a bit, allowing it to contact a spot on the drum with each revolution.
Posted on Oct 02, 2008
Drum will not turn
there is a belt that drives the drum in your dryer it is broken
the grinding sound is caused by the the wheels that the drum rides on broke or the bearing went out
Apr 14, 2014 | GE Dryers
Frigidaire dryer has recently become noisy. scraping, grinding sound. dont know if its belt or motor. any info b4 i take it apart? no error lights on panel.
The problem with the dryer is not the belt or the motor. the problem is either going to be the drum bearing or the front upper and lower felt and glides.I'll list a walk-through for you if your interested .
1)The first thing you need to do is unplug the dryer.
2) You will need to pop the top of the dryer. This can be done with a flat screwdriver. Place the driver between the top and the front of the dryer and basically just pry upwards.
3)Now, that you can see inside the dryer, the next thing is to remove the front of the machine. At the upper left and right sides you will find a screw that holds the front to the frame of the dryer.Remove these screws and you can take the front off.
4) The glides and felt are located on the inside of the front piece you just removed.The drum actually rest on these and if damaged will produce a metal on metal dragging sound. If these parts are good, continue to step 5)You now have access to the belt and idler pulley, which is good because the belt needs to taken loose .
6) WIth the belt off spin the drum and listen for the sound that has been bothering you, if any sound other than a smooth sound is emitted when turning the drum your rear bearing is out.
7)You can remove the drum by lifting the back end up and pulling it out. Once you have it out the bearing will be exposed and the rest is just swapping out the old bearing and putting it back together.
Jun 16, 2012 | Frigidaire Electric Dryer
My GE electric dreyer, DHDSR46EGWW, is making squeaking noise and a grinding noise. My husband took is apart last night and put back together. When he started it the noises came back and he said it...
It could be the rear bearing or if not it have your honey take it apart again and inspect the rear rollers, if they turn freely then inspect the front bearing assy it is on the the door and if it looks worn down then it is allowing excessive pressure on the rest of the unit .
Apr 01, 2011 | General Electric DHDSR46EGWW Dryer
GE Dryer MOD: BBXR463ED2WW SER: ZH775302A Dryer is getting louder when in use it creams when in use. think it might need a belt? other problem: When I turn the controll settings it goes on without turning...
The roller for the belt tensioner has a bad bearing. replace that item as well as the belt
The start button is stuck to the start position so replace that as well
The top & front panel will need to come off to repair both items
May 23, 2010 | GE DBXR463EDWW Electric Dryer
Dryer makes loud noise is a ge has thin belt on it. belt is ok seems like the tub doesent turn as fast as it did.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
whn
Mar 09, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer drum does not turn - only by hand?
Try this link, the first one the maytag one has the actual instructions, all dryers a pretty similar you just have to route the belt according to the diagram!! Good luck,, ps a good rating would be nice! thanks
http://fixitnow.com/wp/2004/08/19/appliance-repair-revelation-how-does-that-dryer-belt-go-back-on/
May 10, 2009 | Dryers
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
I have a whirpool dryer Mod#LER5620KQ1 the dryer makes a grinding noise when you turn the power on what can this possibly be
Check for metal shavings under the unit pull off the back cover. It seems like this can be one of a couple things. Bad main bearing, your clutch is not fully disengaging or the brake is not disengaging
Feb 18, 2009 | Dryers
Dryer Making a Grinding Noise
The grinding noise is probably a worn out roller or the central bearing in the back. The center of the drum in the back has a part called a bearing which screws onto the back of the drum and has a stub which sticks out. The stub then goes into a bearing hole in the back panel of the dryer. If you are handy, you could try to replace yourself. I did it once. While you are at it, check the drum belt which goes around the drum and makes it spin. Replace it if looks like it has wear.
Feb 01, 2008 | Kenmore 63942 Dryer
Dryers Logo
157 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
