Question about Whirlpool Refrigerators
I am trying to find a thermostat for a whirlpool ART 517/G any idea where I can get one
  • 3 Answers
Http://www.fridgeshop.net/ can help
Posted on Feb 27, 2010
Ice lump build-up on left side of the lower back panel inside the fridge section of fridge freezer. Compressor is on continuously. Any help appreciated. Thank you.
Check the operation of the thermostat. Try raising the temperature og the refrigerator side and see if the compressor stops.
Oct 30, 2017 | Whirlpool Refrigerators
Why is the door seal warm on whirlpool refridgerator
Your refrigerator has a defrost wiring system in the seal to keep moisture out.
They run continuously on older units and some newer ones too.
Depending on the age of the fridge, some rarely have thermostats or timers on the defrost seals. But like I said they're rare to have a thermostat on the seal heater.
Those seals with their defrost wiring inside are some of the reason that manufacturers changed the defrost approach to get energy saving ratings.
Auto defrost, timers and defrost thermostats are state of the art now and cost less for you to run in your house.
If your symptom is new, or you notice the door seal heat too hot to touch, then your seals have a problem. You need to call for service because overheating defrosters may not shut off.
Warm seals are most likely a normal condition for defrost system on your fridge.
Luck to you.
Isn't this a good site?
Russ
Dec 23, 2010 | Whirlpool ED5FTGX Side by Side...
WHIRLPOOL FRIDGE FREEZER MODEL ART 201. REPLACING
It is often the case that if the thermostat is not working, the best route to take is to replace it rather than try to fix it, unless you have the necessary knowledge to do so. Most of the time, these are not as expensive as you would think and can be easily installed into the refrigerator. Here are some steps to follow to find out what the best route for you to take is in repairing or replacing your thermostat.
Good luck.....
Locate the thermostat and get all necessary model numbers, serial numbers and model codes. This information should be available for the refrigerator itself as well. Use this information to find and purchase the correct thermostat for your refrigerator.
Next, remove all power from the unit. Unplug the unit completely and make sure that it is not running before moving forward. Then, remove the old thermostat by cutting through the wiring.
To install the new thermostat, trim the lead wires to the right length. They are generally too long to start with. Terminate back into the circuit. The device will act as if it is a switch. This means that the direction or the coloring of the wires is not important. So long as you can cut off the current moving through them to the main defrost element you have no problem.
Make sure to properly dress the wires to insure that no part of them comes into contact with the defrost elements as this can cause them to melt.
Replacing a thermostat doesn’t have to be a lot of work, when you know what the problem is and can get easy access to the parts you need. Determine if your thermostat is bad by running through those tests first. When you do replace it, make sure to test to make sure it is working properly by allowing the unit to cool for several hours and testing the temperature within it.
Jul 30, 2010 | Whirlpool Refrigerators
My whirlpool freezer sat for a year and now I can't get it to turn n. Any ideas?
it is either your thermostat or the overload relay. if it make a loud clicking noise every few minutes than that means it is your overload relay with is on your compressor but if not the it will be your thermostat. try tapping on it.but most likely it will need to be replaced
Jul 03, 2010 | Whirlpool 10 cu. ft. / 283 liter Chest...
Whirlpool refer section freezes the food - I have the Tstat turned off, and it looks like it still is frozen. Any ideas?Thanks Tim whirlpool no frost model EHT171HKNR3
If it is running and the thermostat is turned to the off position, then the thermostat is bad, and needs replaced.
For some reason more common a problem on Whirlpool machines, but a fairly easy repair.
Mar 23, 2010 | Refrigerators
Samsung laptop r 517 display driver for windows xp not installing so it not gives proper display in xp operating system
Hello saisantoshil,
Please check this out,
http://www.megaupload.com/?d=HAHC9NBB
Hope this helps.
Art Pena
Tech Support
Nov 23, 2009 | Samsung NC10-14GW Notebook
Greetings! My Whirlpool 21 is not cooling on the bottom, but the fridge is OK. Art
I do not understand your question because your note says it is a top freezer, but the fridge is ok?
The bottom section IS the fridge on this type.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
Pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Mar 21, 2008 | Audio Players & Recorders
Manual for Solis Master Top 517 Problem
Dear Sir/Madam,
My Solis 517 is not working at all. I get few lights on the front panel but pressing buttons nothing happen.
Can you please tell me what I can look for or what do you think is the problem.
Thank you
Your truly
Joe
Nov 30, 2007 | Solis Master Top 517
Refrigerators Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
