Aiwa stereo turntable system px-e860k
The drive belt has come off. how can i put it back on to the turntable
  • derekgoater Oct 15, 2008
    On lifting the rubber mat access can be gained to a hole in the turntable which just about enables me to loop the drive belt back over the capstan. But it refuses to stay there once the belt is operating.
  • Anonymous Dec 27, 2008
    Turntable does not turn. Were can I get a new belt.
How long have you had it? could be that you just need a new belt if it keeps slipping off...
Posted on Oct 20, 2008
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
How to put the belt on aiwa stereo full automatic turntable px e855
Lift off the rubber cover. On some turntables, you can pull the whole metal platter straight-up now. Put the belt on the outside of the bottom of the platter and drop platter back into the turntable base. Do NOT put the rubber cover back on yet. There should be one or two openings in the platter where you can see the pulley for the motor. Slowly rotate the turntable platter until the opening is over the top of the motor pulley. Now use a nail file to gently pull the rubber belt over the pulley. It should spin freely now. Now put the rubber cover back on and try it out. Belts are available from MCM Electronics and over online vendors. Let me know how it goes. Good luck.
Aug 16, 2014 | Audio Players & Recorders
THE PLASTIC COVER OR LID IS BROKEN FROM MY AIWA PX-E860 TURNTABLE WHERE CAN I BUY IT. SILVIA DE ALBA
I don't think you can find this part easily and new and honestly it doesn't worth it.
I would suggest to go for this or something similar
Aiwa Stereo Full Automatic PX E860 Turntable System
Feb 12, 2014 | Aiwa PX-E860 Turntable
I would like to have a diagram to show how to fit the belt for Aiwa turntable PX-E860K
Good day. I assume that you have lifted the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Feb 13, 2011 | Aiwa PX-E860 Turntable
AIWA PE860U got the platter of and the belt was
if it's falling off regularly, you will need to replace it soon.
Apr 18, 2010 | Aiwa PX-E860 Turntable
The drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Dec 14, 2009 | Aiwa PX-E860 Turntable
Turntable help
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Sep 20, 2008 | Aiwa PX-E860 Turntable
HOW TO INSTALL AIWA PX-E860 TURNTABLE BELT
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. the website shown in the video lists your belt under the "find my player" button on the left side of that site.
Dec 26, 2007 | Aiwa Z-L500 Shelf System
777 people viewed this question
 Grubhead
Grubhead
