Question about Zebra Eltron LP 2824 Thermal Printer
Zebra LP2824 Not Printing
I'm trying to get my Zebra LP2824 Direct Thermal Printer working but it refuses to print anything other than the ZebraNet Print Server Config info.
I'm running Windows Vista and have already installed all the appropriate drivers as well as the ZebraDesigner Pro software. They all installed fine however when I try to print the program freezes and the printer does nothing.
I've checked and double checked connections, pinged the printer and it replied fine, even tried other software applications to get the printer to spit something out.
The print job is in the printer queue, stays there for about 30secs then says error. I've tried dumping (reset) the printer but i'm still having the same issue.
Program works great, computer, router and the whole network can see the printer just fine, they let me adjust the settings too.
I'm at my wits end, any assistance would be greatly appreciated.
Thanks
  • smithirene Nov 16, 2008
    My Zebra LP2824 refuses to print anything other than ZebraNet Printer Server config. Help, I NEED TO BE ABLE TO PRINT MY RETAIL STORE LABELS. This happened before but I can't remember rhe solution.
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Posted on Aug 05, 2009
    Scholar:
  • 45 Answers
I'd try using the driver from Seagull Scientific. I've used them for many types of thermal printers.
http://www.seagullscientific.com/aspx/thermal_printer_list.aspx
They work with Vista, and your LP2824 model is listed in their Zebra downlaod.
Good luck,
Label_Guy
Posted on Oct 02, 2008
Lp2844 sound is coming from printer while printing
Green light red
I've a Zebra LP2824 printer , It gives me the Green-Red error .. And the manual guide told me that's a problem with flash programming .. What can I do to solve it ??
Feb 12, 2016 | Zebra LP 2844 Thermal Printer
I cant seem to get rid of the "Ribbon In" error on my zebra S4M
1st change the print method to direct thermal on the LCD panel,  then check the driver on your computer, make sure you are printing with direct thermal
u can check the driver at printer & faxes , right click the printer and select printing preference .
Feb 11, 2010 | Zebra Z4M Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
My zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
Aug 19, 2009 | Zebra 203DPI Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
My zebra LP2824 Thermal printer is driving me nutty. It skips tags between each printed one. I'm printing on thermal labels that are 1.1875x3.375 (2 side by side) so the total measurements are 2.375x3.375....
possible is not the best printer to work on site-by site labels because the sensors that read the gab are on the midle of the label and possible can't check wen the label start and end. try the printer S4M (sensors on lenf side), or try normal labels and press the botton until flash 2 times and release the botton (calibrate).
Dec 14, 2008 | Zebra TLP 2824 Printer
Slow printing to LP2824
This appears to be normal operation.
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra Eltron LP 2824 Thermal Printer Logo
4,200 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
