Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
TV won't turn on.
My Panasonic plasma TV won't turn on.  I disconnected it from the power supply, waited, pressed the power button it made the clicking sound but then made a "winding down" sound and the red power light started blinking. Help.
  • 1 more comment
  • pfournier2 Oct 06, 2008
    It just stopped
  • bobtheasian Oct 31, 2008
    My TV won't turn on. I've tried everything from hooking it to a new outlet to disconecting it for a day and trying it again the next evening. when I press the power button, it makes a sound like it will turn on but doesn't and the light starts blinking. PLEASE HELP!
  • Stuart304 Dec 14, 2008
    The TV just switched itself off. Minutes later, after several attempts to turn it on (light flashing as described by other users) it came back on but only for less than a minute and then turned itself off. Now the light just blinks continuously and telly refuses to come back on. Fuse changes did not help!
Hi i had the same problem,
did you check the fuse if it looks burnt out you can get a new one from a b&q or a hardware store
hope it helped
Posted on Oct 05, 2008
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Panasonic TC-42PX14 wont turn on power light flashes 1 time
You may want to shop for that board or at least consider removal of the HDMI socket in question---tested for shorts there I presume?
Nov 05, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button blinks TEN times.
Check and see if there are any blown caps on the power supply. If there are replace them or change your power supply.
Thank you
Mar 20, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button is just blinking. What can I do?
All you can do is: Take the plug out of the wall (power) - wait 2hrs, plug in and try again. If it will not work after being cooled and the capacitors drained (which this will do) then it needs repair.
Plasma TV will not turn on
The 7 blinks means that the SC scan drive board might need to be replace but only after checking the voltages from the power supply. If the voltages from the power supply are normal, then proceed to replace the SC scan board.
Click here to find the board you need.
Dec 20, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
449 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
