Question about D-Link DP-301U (790069251979) Print Server
D-Link 301U Printer Server using Windows Vista
This printer Server works Window Vista?
I can not print through local network. I can not find driver for Window Vista. Is the problem draiver? Other computer using Windows XT works well
  • okminc Apr 25, 2009
    Thanks for your great help
    Novelist:
  • 169 Answers
As shown here on the Dlink website, there is no support for either Vista 32bit or 64 bit
Hope this helps - remember to rate!
Posted on Oct 02, 2008
Here it is listed as compatible: http://www.dlink.com/products/vista-support/
The above says no Quick Installation Guide only.
Posted on Oct 09, 2008
I am using DP-301U print server and wanting to attach with hp 1020 plus. However the printer in not printing. what is the root cause and give the solution please...
Hello and welcome to fixya.
First off, I would like to provide you a link with the print server's manual to download it directly and have it as spare.
The printer you are trying to install is a laser printer (black/white only) and probably a bit old model.
Therefore, if you are trying to print from your computer over ethernet, and you have windows vista or 7 (64 or 32bit accordingly) you might have the inappropriate drivers for either the print server or the printer. You can find all of the HP printer's drivers HERE. Select carefully based on your OS.
As a SIDENOTE: If you just need the drivers installed and there are only larger setup execut. files available, you can use 7zip or winace to open up the *.exe file and navigate to the appropriate folder and extract only that one to your computer and install the driver(s) from there.
The D-Link DP-301U print server drivers are available HERE. Default username and password for the management console of the print server can be found at pdf manual page 25. The url to access the administration console is dlink-******,where the asterisks stand for the last 6 digits of the print server MAC address.
Overall, not to make things over-complicated (150+ PDF user manual pages) you need to do the following:
1. Install the appropriate drivers of your hp printer on the computer that will have also print serv. softare installed.
2. Install the appropriate software/drivers of the dlink print server on the same computer.
3. Plugin the usb cable of your printer to the print server's USB port.
4. Plugin the ethernet cable of your print server port to the ethernet port of your home router/switch.
5. Setup Fixed IP settings for your print server configuration (page 20 on the manual).
Let me know how that went. I believe you will manage to do it that way quite easily.
**Don't Forget to vote how helpful this was.**
Thanks.
Regards from FixYa.com
Apr 22, 2011 | D-Link DP 301U (DP-301U) Print Server
I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Oct 20, 2009 | D-Link DP 301U (DP-301U) Print Server
Printing Problem
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
No documents are sent to the print queue when attempting to print to a printer through a DP-301U. Printing in Vista works fine, but not so much with XP.
Check and see if the drivers are installed correctly and configured on both pc's.Then see if the printer is installed and that sharing is enabled on the network. Mike tekman2300@yahoo.com let me know when you complete these steps and if it worked.
Aug 08, 2009 | D-Link DP 301U (DP-301U) Print Server
USB printer HP 1020 Plus in DP-301U
Did you try using LPR mode instead? I find it works more relyable with any print server. SMB (windows network mode) is ****. I have had simalar problems with another printserver.
Apr 17, 2009 | D-Link DP-301U (790069251979) Print Server
D-LINK PRINT SERVER DP-301U AFTER DOING A SYSTEM RESTORE ON MY DESKTOP COMPUTER (WINDOWS XP) I CAN NO LONGER PRINT TO MY SAMSUNG ML-2010 SERIES PRINTER ... PRINT JOBS ARE IN THE PRINTER QUEUE BUT WON'T...
- Kindly visit this web site for instructions:
http://support.dlink.com/faq/view.asp?prod_id=459&question=DP-100%20/%20%20DP-101P+%20/%20DP-300%20/%20DP-301P+%20/%20%20DP-303%20/%20DP-313%20/%20DP-301U%20/%20DP-311P%20/%20DP-311U%20/%20DP-311U_revB
Mar 12, 2009 | D-Link DP-301U (790069251979) Print Server
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP-301U Problem
    It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
    Is this the wireless print server?
    What specifically do you mean by PJL printer block?
    Aug 04, 2008 | D-Link DP 301U (DP-301U) Print Server
    D-LINK DP301U
    TCP/IP printing for windows xp:
    you must know the IP address of the print server and the port name.and the pc's ip address must be in the same subnet as the print sever's ip address.
    Step 1 Go to Start > Settings > Printers and double-click the Add Printer icon to open the Add Printer Wizard.
    Step 2 Select Local Printer and click Next.
    Step 3 Select Create a New Port and choose Standard TCP/IP Port from the drop-down menu and click Next.
    Step 4 This will bring up the Add Standard TCP/IP Printer Port Wizard. Click Next.
    Step 5 Enter the IP address of the print server and the port name and click Next.
    Step 6 The next window will prompt you for the Device Type. Select the Standard radio button and use Generic Network Card from the drop-down window.
    Step 7 Click Finish to close the port configuration wizard.
    Step 8 This will bring you back to the Add Printer Wizard. Step through the remaining windows of the Add Printer Wizard, accepting the default values to complete configuration.
    May 29, 2008 | D-Link DP 301U (DP-301U) Print Server
    Scanner
    This is not a solution just a possible fly in the ointment. I have often found that scanners only work when attached directly to a computer. Scanning over the network is not a solution I have found. You can always share out the printer from the attached pc.
    Jan 09, 2008 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP-301U (790069251979) Print Server Logo
    1,687 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
