Question about Whirlpool Dryers
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't extra wet when i put them in the dryer. I can feel the heat in the dryer when its running, so i know its heating. I'm not even putting allot of clothes in the dryer.
  • john gagnon
    john gagnon May 11, 2010
    hi thanks for the question. did you also clean the venting to the outside. very important get back to me
  • 943 Answers
Hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Posted on Oct 03, 2008
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
On the screen of my dryer where it tells me how long I have till the cloths are dry keeps flashing AF and it takes me all day to dry one load of cloths.
The AF stands for Low airflow condition. We had it too. Check the lint trap first as it is the easiest. Then check the dryer hose ductwork make sure its not crushed or blocked. You may need to clean the line from the outside too.
Dec 30, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
The clothes take forever to dry. Even with the more Dry cycle the clothes are wet after 40+ minutes The timing changes from 40 minutes then to one hour+.....
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Nov 23, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
After drying for 75 minutes timed cycle, my clothes are still damp. I also cannot get clothes dry on the normal cycle at all.
Things to check:
Make sure the dryer is heating up
Make sure the lint screen is clean
Check the vent to make sure it isn't obstructed or plugged (this is the pipe that goes to the outside)
Make sure the unit isn't overloaded
Check the spin cycle of the washer - if it isn't spinning out enough water for the load, the dryer can't make up the difference - sometimes this is as simple as a plugged discharge filter on the hose that goes to the drain.
Dec 23, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Whirlpool Dryers
Whirlpool 6.5 cu ft 5 cycle is not timing and drying clothes qui
First I would check to make sure your vent is not clogged or kinked. As far as the timer, the only fix would be to replace it. Unless of course you have the feature that detects the dryness and that would put you back at the venting problem. Good luck.
Apr 17, 2009 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Alarm sound while drying
It sounds like you have it on the "wrinkle free cycle". (I can't remember what the cycle is actually called with out looking it up.) It will tumble your cloths and then alarms to tell you to take them out before they wrinkle. If you don't take them out, it will tumble them again and alarm again, etc.
Apr 13, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
287 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
