Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Stuck in standby
My Sony Trinitron was working one minute now my TV screen won't turn on...has 4 blinks in Standby. . TV screen won't turn on...has 4 blinks in Standby. I've tried the hard reset..leaving it turned off for 5 hours..nothing.
  • 2 more comments
  • ravenphotogr Nov 25, 2008
    blinking 4 times in standby and won't turn on
  • themarkp Nov 26, 2008
    I have the same problem of being stuck in standby, but the blinking is a steady, constant on and off.  I tried the recommended unplug for 60 seconds and plugging into the outlet rather than a surge protector, but no luck.  Help!
  • Anonymous Nov 27, 2008
    Does anyone have any idea what 6 blinks indicates mine is blinking 6 times after the power button is pushed..
  • camfam04 Dec 30, 2008
    had a brown out... had the tv on a protector with a fuse.  It is blinking 4 times with a clicking sound as if it is trying to turn on but does not... then it clicks off.  My husband will attempt to fix this - we have been told it is either a fuse or a circuit.  Can we get schematics or can you tell us what to do?  KV32FS12 - Thanks, Chris
  • 4,234 Answers
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
  • Samantha Smith
    Samantha Smith Jan 16, 2016
    I am having the same problem with my tv it's not working today and i have tryed everything i have no remote control for the tv van u help please
Posted on Nov 03, 2008
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My Sony Trinitron won't turn on...has 4 blinks in Standby.
There are 3 reasons for 4 blinls
1.unit went to stand by mode because of h-pulse
2.Vertical defflection pulse stopped
3. power line is shhorted or power supply is stoped.
Solution:
1. check 13vdc on A board of powersupply stage
2. Check IC561 on A-board.
Good Luck
Dals123
Sep 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
This may be a vertical circuit problem. IC1509 is usually the vertical IC. If you can solder, I would first try an resolder the pins on this IC. If that fails to resolve it, replace the IC. This IC is a small flat IC attached to a heat sink with about 11 pins. It will be marked LA7837 or something similar. Feel free to post the marking and I'll confirm you have the correct IC.
Keep me posted.
Dan
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
1,370 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
