2004 envoy xuv low beams dont work switched fuses 45 and 46 still nothing any ideas
Last night low beam headlights wouldnt work all other lights including
high beams work. checked both 10 amp fuses and they look good
switched 45 and 46 and still no low beams.
Before you replace the #46 HDM relay (in the fuse block under the hood) try exchanging it with the #45 cooling fan relay and see if your low beam lights work. If they do, the HDM relay (actually solid state module, not a relay) is bad.
I don't believe there is a fuse. There is a circuit breaker built into the headlight switch. If you are sure the headlight switch is good, it could be a bad dimmer switch. If you have a voltmeter, with the headlight switch turned on, a larger yellow wire going from the headlight switch to the dimmer switch should be a hot wire. The dimmer switch sends power on a tan wire to the low beams, and through a light green wire to the high beam bulbs.
If your high beam indicator on the dash also doesn't work, then it is likely one of those switches. A voltmeter or test light would need to be used to find which one is bad. If you can find the connector at the steering column going to the dimmer switch, pull it apart and check for power on the yellow wire coming from the headlight switch, with the headlight switch turned on. If no power, the headlight switch is bad. If there is power there, then the dimmer switch must be bad.
Try to see if the bulbs blew out by replacing the bulbs first. If they still won't light, it could be bad grounds or connections or bad continuity in the wiring to the headlight relays or switch. Good luck on this repair.
Why yes there is. It's #46 under the hood. Switch relay #45 with #46, do you now have lights? Either clean the contacts by pushing it in and out of the fuse box, or buy a new relay. Cleaning the relay worked for me, but I keep a spare just in case. Very common problem with Envoys and Trailblazers.
Hello, try to start by checking the headlight relay and headlight fuse. You
also may want to check to make sure the bulbs aren't blown out. If those
parts check out to be fine and in working order, you may need to
replace the turn signal assembly in the steering column. This part
controls the hi/low beams. This may sound crazy but, when GM wired
their older trucks, they wired the headlights to go from the battery,
to the hi/low beam switch, then to the headlight switch (to the left of
the steering wheel) then out to the light bulbs. You can kind of test
to see if this part is good by making a fist and (with your headlights
on) gently hitting the plastic cover for your steering column that is
right behind your actual steering wheel. This could cause your
headlights to flicker on and off.
Relay in fuse box under hood on driver side wheel well labeled HDM, #46 on 2004 Envoy XUV. Swap with relay #45 labeled "Fan" to test. That was my problem.
