Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Connects to home hub but not internet?
Why wont it connect to the internet?
it connects to the home hub but not to the internet?
  • beeber87 Oct 17, 2008
    I have the same problem. It shows that the internet is there, but it says that it is scanning and will not connect.
  • 27 Answers
WOAH Unistalling drivers is jumping the gun!
You could potentionaly breaksomething doing that, save that for later there are much more common issues.
1) restart router.
2) If you are connected to your router but dont have internet call your provider.
3) If your on windows and you can see the network but cant connect to it try the windows trouble shooter (it accutely works) if it says that you have an ip confilct you want to manualy change it (just google it, its easily done) If your using XP or macc this can be a common issue becuase some routers dont support them propperly.
4)make sure you have a decent connection when you first connect as the router and computers are extchaning important data.
5) if you have a super hub go to 192.169.0.1 in your browser (big HTML bar at the top). If your on another router you will have to google it. Alterntivly if you can connect in windows go to the network map in the networking centre in the controll pannel and double click on your router. Once in there should be a diagnose tool
6)reply to this post and tell me how it went :)
good luck.
Posted on Apr 15, 2014
Belkin adapter has a signal says its on but wont connect to the internet helpppp
Posted on Oct 15, 2008
2 Suggested Answers
  • 6 Answers
SOURCE: wont connect ti internet
Same device as mine. and im on home hub aswell. Uninstall the drivers. Restart windows. Reinstall the drivers. Hopefully this should make a differance. Also when reinstalling. make sure the device is not plugged in until you finish installing drivers. And maybe put it into another usb when you are ready to try again. this is something good to try on older systems. or OS's.
Posted on Jun 12, 2009
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
I cant get my home computer and lap top to both go on line at the same time
A "hub" just "splits" the Internet connection.
Each computer connected to the hub gets an IP-address from your ISP (Internet Service Provider).
However, some ISPs only allow each customer to use _one_ IP-address.
Ask your ISP for the capability to obtain a second IP-address.
Mar 18, 2011 | Linksys (NH1005) 5x10/100 Mbps Networking...
My hp pavilion dv 9000 can not connect to bt home hub 2.0
hi, please make sure that you enable WPA encryption on the wireless router. Vista will give you trouble if you use WEP encryption. Also, please update the firmware on the wireless router, if possible.
Let me know how it goes.
Oct 26, 2009 | Computers & Internet
Pc wont connect 2 my home hub
hi, you can do two things.
1. call the customer support of the brand of your router and get the setting of your home hub verified.
2. also call the customer support of the HomeHub company you are using.
3. if its both of same company they no need to call to customer cares.
4. hope you had secured your wireless otherwize might be hacked by neibours some time.
diffucult to help by any fixya, its the customer care who will check your config(e.g dns etc)
Rate me Rate me.....I am a fixya.
Mar 26, 2009 | Mozilla Firefox
Wont connect ti internet
Oct 02, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
3 com hub tp4 home network setup failure
There are several possible problems here, and more information is needed to identify which one is causing trouble. First, are you using a high speed dsl or cable internet connection? ...or is your Internet connection a dial-up phone line? This will have a significant effect on how your cables should be connected between the hub and the computers. Windows typically defaults to a 169... address when it is not properly connected to a shared network connection.
Jan 08, 2008 | 3Com HomeConnect (3C19261) 5x10/100 Mbps...
Connecting to the Internet with more than 1 computer (using a PureData 16 port device)
The PureData 16 port is just a hub and does not perform any of the housekeeping functions you would need in order to create a home network and connect several computers to the Internet at the same time. The reason why your procedure works is because your service provider by default will only allow you to have one IP address. When you unplug your modem that forces the providers equipment to reconnect to your computer and reissue the IP address. The way to get your desktop and laptop to connect simultaneously is to go down to your local computer store and purchase a home router/firewall. I?ve seen some on sale for as little as $35 at times and are fairly easy to setup. Good luck and let us know how it goes.
Dec 25, 2006 | Puredata (PDC8023UAS-16FX) Networking...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
486 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
