Thomson DTI550 set top box problem
I recently pressed add new services on this set top box. The new services were added but the existing channel numbers were changed by the box. Channels numbered 1,2,3,4,5,6 etc. are now in the high 800,s. Is there any way to renumber these channels?
  • 7 more comments
  • Anonymous Oct 15, 2008
    I did exactly the same, tried to download new channels and lost channels like BBC, STV which are now sitting at 826 etc
  • Anonymous Oct 26, 2008
    The same thing happened to my receiver around August. I was about to buy a replacement. There doesn't seem to any way of editing the EPG.
  • dj427 Oct 26, 2008
    Exactly the same happenend on mine added new channels but now they are all over the place, bbc programmes in the 800's
    Exactly as described by others, downloading new services re-numbered existing channels so that BBC1, BBC2, ITV etc are now three digit numbers instead of 1, 2, 3 tec.
  • Anonymous Nov 01, 2008
    I have the same problem - does anyone know a cure?
  • big_v2000 Nov 06, 2008
    yup - i have exactly the same issue.
    i'm about to take mine apart to see if i can reset it inside
  • pengir1 Nov 07, 2008
    Same problem as previous user's. Keep either replacing existing services or adding new services and smae problem occurs (i.e. BBC channels stored as 847 etc..., and other channels not assigned a programme number at all)'
  • debred1986 Nov 20, 2008
    i have the same problam, all the channels are now in the wrong order, numbe one is now 816 or something like that. Very hard to find channels you want to watch.
  • CYBER-DEMON Mar 21, 2009
    Add me to the list of people experiencing this problem! I've just had to set it back up and this happened.
Hopefully those of you who still own their DTI550 had it operational this last weekend and picked up the download that fixed this? If not, it should be repeated some time soon. So don't throw your 550 away yet!
Posted on May 13, 2009
I'm beginning to think that there will not be a download for the DTI 550. I've just searched the Thomson website and they say that they no longer offer support for these products in Europe.
It looks like it's destiny is the bin.
Posted on Nov 07, 2008
The transmitter has been upgraded, go to go to www.freeview.co.uk web page, upgrades/downloads are coming out fo older boxes
I have exactly the same issue and about to take it apart to see if there is a master reset inside.
I'll keep you all posted...
Posted on Nov 06, 2008
    Well I took it apart and there is no internal reset switch or battery.
    So I deleted every channel manually, pulled the power and auto tuned, but to no avail (BBC1 on 815 still).
    I then deleted Program 815 and tuned Program 1 manually on 490MHz. It found 6 new channels and added one (my missing BBC1 channel). Unfortunately, it added BBC1 to 815 again.
    I have no ideas now unfortunatley.
How do I add channels using the remote?
YOu cannot ADD channel to a CRT TV anymore because Analogue transmissions no longer prevail.
You must use an HDTV digital set top box connected to the antenna input. These have an "Auto tuning" facility which you access from the MENU options. Any new channels which come into being will automatically be added into the memory of the set top box. You just need to remember to do a retune every so often to find out if other channels have come "On Air".
Jan 17, 2015 | Televison & Video
I have got a new Toshiba Regza I have tuned it in but don't seem to have got all the channels can u help
you will need first to configure the antenna sources where you want to program channels. and then you can add channel through your remote control. to add channels in the channel memory, first press MENU and open the set up menu and then highlight installation and press enter. a new set of installation menu icons will appear on the screen. open the terrestrial menu highlight channel add, and then press enter. the list of channel program from the antenna source that you select will appear on the screen. to add now a channels to the channel memory, highlight unchecked box next to the channel number you want to add, and then press enter to check the box.to save new settings highlight done and press enter.
Apr 19, 2011 | Toshiba Televison & Video
Trying to set up my thomson set top box but it won't find any channels - what am i doing wrong? Cheers, Mina
You need to set your tv to the output of the set top box. Hopefully NOT a cable company style cable, but rather RGB or HDMI.
Sep 30, 2010 | Televison & Video
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson dti6300-16 won't record freeview channels....
maybe a defragged hard drive follow this procedure:
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Oct 02, 2009 | Arris DCT2608
Samsung LE32R7 in DTV mode stays on BBC1
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
We are receiving channels 1-13 only; don't know how to add more
make sure you have your tv set to cable, if you have a set top box unplug the box plug it back in reboot it, like i said make sure your tv is set to cable then do auto channel scan should work good luck!!
Apr 12, 2009 | Toshiba MD20Q41 20 in. TV/DVD Combo
I get " instead of @ when pressing shift and no.2 keys....why?
Sounds like you have UK instead of US keyboard setup
Here is the fix.
  1. Click Start and then Control Panel
  2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
  3. Open Clock, Language, and Region
  4. Click on Regional and Language Options.
  5. Click the Keyboards and Languages tab and then click Change keyboards.
  6. Under Installed services, click Add.
  7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
  8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
  9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Televison & Video Logo
1,001 people viewed this question
Top Televison & Video Experts
Electro Med Services...
