Question about Lexmark X500N Printer
Extremely S L O W to print
My Lexmark x500 printer is connected to a network. All connected computers are Macs. Usually it prints without a problem but today and every so often it takes about 20-25 minutes before it prints the document. Unfortunately when a client is waiting that is not an option.
5 Suggested Answers
  • 14 Answers
SOURCE: Lexmark T642 Slow Slow Printing
I've had this problem with the Lexmarks's T640 printers connected via USB to Mac OS 10.5.5 machines.
Problem: The Mac OS' default resolution of 1200 DPI for this printer causes the printer to have to rasterize the print job again AFTER it arrives at the printer. The printer does a painfully slow job of this.
Solution: Change the default resolution of your print jobs to "600dpi".
Instructions:
1.)Call up the printer settings menu by starting a print job and clicking the up-arrow next to "Printer" box.
2.)Click on the drop-down list with the name of your application and choose "Printer Features".
Change your resolution to "600dpi". Oddly, I find that "1200dpi Image Quality" is almost as fast.
3.)It might be a good idea to "Save as" this new configuration in the "Presets" menu at the top of your list.
You should notice a tenfold increase in the time it takes the printer to actually produce print jobs now.
Additionally, in the "Color Matching" settings (you can get there by changing from the "Printer Features" settings), be sure that you are using "ColorSync" so your printer isn't having to do any additional processing in that area.
Posted on Dec 16, 2008
  • 5 Answers
SOURCE: My Lexmark 9350 won't print from a wireless notebook.
If you are using a Vista machine. First,make sure you don't have two conflicting firewalls active in your firewall menu. If you have a built in firewall in your dsl or cable modem I suggest not using windows firewall. If you don't have two firewalls active and you are only using Windows firewall, you may have to allow the spool portions of your lexmark program through Windows firewall manually.Check your windows firewall and make sure all parts of the lexmark application are allowed.Also make sure you have installed the latest lexmark drivers on your notebook via lexmark update. I suggest anytime you are installing drivers that you install them using your administrator account. I also recommend unblocking the installation exe before you install. To do this when you download the update, right click on it click on properties click on "unblock" at the bottom then click ok.Right click again on the installation exe and click on administrator. This gives you administrator rights to run and install all portions of the exe file.
Posted on Apr 15, 2009
techbuster
  • 5081 Answers
SOURCE: Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Posted on Aug 19, 2009
etaf
  • 779 Answers
SOURCE: my lexmark x4650 is supposed to print wirelessly.
reset the network connections Procedure: Resetting the Network Settings
  1. Press Setup ().
  2. Press the right or left arrow button until Network Setup is displayed, and then press .
  3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, and then press .
  4. Press the right or left arrow button to display Yes, and then press .
  5. Observe the message "Clearing Wireless Settings".
  6. NOTE: You will not be able to navigate the menu until this process is complete and the Wi-Fi light resets from to orange ().
http://support.lexmark.com/index?page=content&id=HO3371&actp=search&viewlocale=en_US&userlocale=EN_GB&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4650&searchid=1270310780939
Guides available from this link http://support.lexmark.com/index?locale=en&segment=SUPPORTproductCode%3D&startover=y&userlocale=EN_GB&question=Lexmark_X4650&productCode=LEXMARK_X4650&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X4650&searchid=1270310775279#3
Network Guide available from here - under documentaion http://support.lexmark.com/index?page=content&actp=PUBS&locale=en&segment=SUPPORTproductCode=&userlocale=EN_GB&id=PU45811&productCode=LEXMARK_X4650
Use guide http://support.lexmark.com/index?page=content&actp=PUBS&locale=en&segment=SUPPORTproductCode=&userlocale=EN_GB&id=PU45810&productCode=LEXMARK_X4650
Posted on Apr 03, 2010
How can I get my IPad 2 to print on a Lexmark Prospect Pro 205, without keeping my laptop wired to the printer? I do not have a desktop.
Your printer and the devices trying to print from it should be connected to the same network. If it is, download our LexPrint app to your iPad http://bit.ly/IMbDlq. Since the Lexmark Pro205 is not AirPrint compatible, you would need the LexPrint Listener installed to a host computer.
Our latest Inkjet printers are already compatible with AirPrint.
Aug 17, 2012 | Lexmark Prospect Pro205 Wireless...
Why will my T632 not print over Wi-Fi from my 2011 iMac (10.7.4)?
If the Lexmark T632 is already connected through the Ethernet, it will not be possible to connect it through wireless. The printer cannot be configured with both the Ethernet and the wireless function enabled. The printer will choose the physical connection (Ethernet / LAN) over the wireless connection.
Aug 03, 2012 | Lexmark T632 Laser Printer
Is this printer air printer capable
Lexmark introduces the Lexmark LexPrint Mobile Print Application that lets you print photos from Apple devices such as iPhone, iPod Touch and iPad using any Lexmark printer connected to the same wireless network.
Simply download and install the LexPrint App on your Apple device. For the Lexmark X9575 printer, you will also need to download and install the LexPrint Listener Application, as well, on your computer that is connected to the same wireless network.
Your computer will have to be "on" in order to successfully print from your Apple device to the Lexmark printer.
I hope this information has been helpful.
Dec 28, 2011 | Lexmark X9575 InkJet Printer
900 service RIP software error - how do you fix it?
Please try to do the following steps. Remove parallel, USB, and/or network connections andrecycle the printer's power so that it is operating as a standalone machine. If it powers up to the Ready state, print the MenuSettings page(s) from the Utilities Menu. If the printer works without error while disconnectedeither from the network or a locally attached computer, there is a strong possibilitythat a corrupted file or network/parallel/USB connection is causing theerror. Look for patterns such as aparticular file or a particular workstation generating the error when data issent to the printer. Clear the print queue and connect all cables back andturn the printer back on. Resubmit the print job(s) and try printing again b> If the error will not clear, please take note of thesecondary code and contact Lexmark Technical Support.
Feb 07, 2011 | Lexmark T522 Laser Printer
I am running this Lexmark 6150 printer connected to the computer via usb cable. I have a wireless laptop, how can I print on the Lexmark 6150 from the laptop the laptop is connected to the same modem...
You can enable printer sharing on the computer where the printer is connected, then share the printer so it can be accessed by others on the network. The steps vary depending on which version of Windows the computer is running, so use the help screen. The steps will be listed for you to follow.
On your wireless computer, add the Lexmark printer as a network printer. You will probably need to install the printer drivers, so have the CD handy or download them from Lexmark's website.
Make sure both computers are members of the same workgroup, or the wireless computer won't be able to find the printer on your network. Also, the computer the Lexmark printer is connected to must be on and running for printing over the network.
An easier way to share your printer is by using a USB print server. One example is here. The server connects to your printer by the USB cable, and by an Ethernet cable to one of the wired ports on your router. Then any computer on the network can use the printer at any time.
Jan 09, 2011 | Lexmark X6150 All-In-One InkJet Printer
We have four computers, 3 Macs and a PC networked via an Apple Time Machine to a Hewlett-Packard HP Color LaserJet CM1312nfi MFP. All of the Macs display "Looking for Hewlett-Packard HP Color...
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
Nov 23, 2010 | HP Office Equipment & Supplies
I NEED HELP A.S.A.P-Lexmark T622
Re-install the printer. That usually fixes most problems
Sep 12, 2009 | Office Equipment & Supplies
Printer connected but not printing.
If you are not sure of the location of the router, it occurs to me that you could not be certain that the printer is configured therein.
If there is a person who normally manages the router which location you don't know, then they should also configure the printer to incorporate it and the two macs as part of your network, or your printer will never work.
Apr 25, 2009 | Brother MFC-820cw All-In-One InkJet...
How to install the lexmark E120 network printer
to clarify this, you need to install the printer in a computer that is connected to a Local Area Network lets call it computer 1. Once the printer is connected to the computer 1, share the printer by going to the start/settings/ printers. Right click on the lexmark e120 printer and click share. Click share this printer. Once done the printer that is connect to computer 1 is now on the network. on the other computer lets call it computer 2, to to start/settings/printer and click add printer/ select network printer and then browse the printer in the network and select it so that it will be added. Now you computer 2 has a network printer installed. try printing, make sure not to turn off the computer 1 when printing, or else it wont print.
Dec 22, 2008 | Lexmark E120n Laser Printer
I have a Lexmark 5490 connected to a D-Link DPR-1260. The D-Link configuration utility installs the printer on my Vista Home Premium laptop as the default printer and recognizes that the printer is...
Check your windows firewall or your antivirus.
Disconnect that for a while and delete all pending documents (queue).
Send a new doc to print and see what happen.
Usually those program are blocking the communication between printer and computer.
If this is your case, set a rule on your antivirus program.
Have a great day!
Pablo :-)
Oct 18, 2008 | Lexmark Office Equipment & Supplies
Lexmark X500N Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
