Question about Roomba Robotic Floor Bagless Vacuum
Roomba Discovery My Roomba Discovery seems to work fine, mechanically, but it no longer seems to collect any dust. (The collection bin remains empty after the Roomba has circulated around the floor for quite a while). The brush has been replaced and spins normally. Does anyone have an idea why this machine's vacuum function no longer seems to work? I would appreciate any feedback. Jeremy
  • l_beith Feb 21, 2009
    My roomba working but not collecting dust, container always empty after it has run.
  • lkarelee Apr 18, 2009
    i have cleaned the filters - and there is a lot of debris on the filter - but none in the collection bin.
  • 120 Answers
Did you replace the filter? when you remove the dust bin there is a small filter that needs to be cleaned, or replaced. You can buy a maintenance kit that replaces the brushes and filters as well, its good to replace them all regularly
Posted on Oct 17, 2008
My Eureka 5892 BVZ-1 vaccum has very little suction. I checked hoes and emptied cup, and made sure filter is not dusty.
There are probably three filters, one on the back of the dust collection bin, one under the dust collection bin, and one where the air exits the vacuum, check all three.
Gary
Mar 04, 2011 | Eureka 5892AVZ Bagless Upright Cyclonic...
Roomba 550 dust bin always empty but filter and brushes always need cleaning. doesn't seem to clean as well as in the beginning
Sounds like you either have a very clean floor, and only dust remains OR, you have dust and baby powder on the floor clogging the hepa filter. THIS time wash the filter with water, then check for blockage in your waste gate area.
Feb 22, 2010 | iRobot Roomba 550 Vacuum
My roomba 560 works perfectly for a year. Now works ok, vacuum but the dust stays at the bruches and at the bin. i replace the filter but nothing. Thanks George
You need to decide if the vacuum and brushes are runing or not. For me its easy to determine after its run. If the brushed turn then I have debris in the open part of the collection bin when I pull it off the back, but none if the brushes don't turn. If the vacuum runs then there is dust at the filter, and none if it the vacuum doesn't run.
You can also remove the vacuum/bin and place the roomba on a hard floor and start it and look into the rear and see if the brushes are turning.
When the vacuum is running there is a noticeable amount of air pushed out the rear vent.
When you've figured out what isn't operating, you'll be halfway to solving your problem.
Nov 30, 2009 | iRobot Roomba 560 Robotic Vacuum
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba Discovery 4120 barely moving
I don't have the same roomba that you have, but I had a lot of dog/cat hair stuck on the fan in the trash bin section. Once I removed that it started to work again. I used an air compressor to give it a really good blow out.
Here is a link that might help you out.
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=10960
Phil
Dec 27, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba brushes won't spin
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Jun 28, 2008 | iRobot Roomba Red 4100 Bagless Robotic...
Irobot moving slowly
Try running th roomba with the dust bin removed to see if the main brush is turning, if not it could be an issue with the gears being stripped in the brush motor assembly or inside the brush compartment holder. If the gears are fine the brush motor itself may be blown. A new one is about $30.00.
May 01, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
Roomba Robotic Floor Bagless Vacuum Logo
230 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
