Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RED TINT OVERPOWERS COLOR
TINT ADJUSTMENT IS NOT WORKING
  • CRARCR Oct 02, 2008
    ARE THESE TUBES AVAILABLE TO THE NOVICE TO OBSERVE?
    ONE THING THAT I DO NOTICE IS OCCASIONALLY THERE IS A BOW OF THE COLORS EMINATING UP FROM THE BOTTOM OF THE SCREEN.
    Scholar:
  • 92 Answers
You're probably missing one of the other colors, green most likely or blue.
There are adjustments that can be made to bring things back into balance but you need to know what you're doing.
First, I'd have a look and make sure all your tubes are working correctly.
Posted on Oct 02, 2008
  • Inno Laur Oct 02, 2008
    No, you'd have to remove at least one cover or the front screen to observe them.
The screen is green and the tint option in the menu cannot be adjusted.
This symptom usually indicates CRT failure. Projection TV's, especially older types use 3 CRT "guns" to project the image on the screen. One is Cyan or Red, one is Green and one is Blue. If the Red and Blue become weak or do not project, the Green gun overpowers the output of the other two. These three "guns" are aligned exactly on top of each other so when all three are correctly functioning, the correct colors are projected on the screen.
Oct 04, 2015 | Televison & Video
Magnavox 9P6034C 60 in. Rear Projection Television Problem. The problem I am having, is that I can not adjust the tint or color, or brightness, whatever I adjust makes no difference. I can move the tint...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Nov 28, 2010 | Philips Magnavox 9P6034C 60" Rear...
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Set on automatic the pictures appear red all over, no other color.
Do you mean orange tint?
The "lighting" is set to "incandescent"
The flash will overpower that issue.
Change the light setting from incandescent to "sunlight"
Sep 30, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Bought 57'' philips tv picture fine but red overpowering
should be a knob on the back inside has 3 one for each lamp red green and blue just turn the red down a little
Mar 26, 2009 | Philips 51PP9303H Rear Projection...
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
