i have the same problem did u fix urs if so can u tell me what u did..thanxi have the same problem did u fix urs if so can u tell me what u did..thanx
AnonymousMar 18, 2009
umm, im just wondering. i recently received a phone with the exact same problem. i dont rele care for using the jack anymore, id just like to be able to charge the battery, so instead of trying to saughter on the tiny pins, y not jsut modify the charger to sharge the battery outside the phone? im sure its possible, if i make any progress, ill post an update umm, im just wondering. i recently received a phone with the exact same problem. i dont rele care for using the jack anymore, id just like to be able to charge the battery, so instead of trying to saughter on the tiny pins, y not jsut modify the charger to sharge the battery outside the phone? im sure its possible, if i make any progress, ill post an update
You can't post conmments that contain an email address.
Well You Can Put Songs as music, but u cannot make them ringtones, depends i think ur phone takes a memory card, mabe put songs on it, then go on ur phone and open music player.
im not sure what your problem is , I think your saying your touchpad is locked and your screen is white so you cant get it unlocked correct....its either if you hold star in or its the pund sign in and it unlocks the key pad worse case take the battery out and put it back in..... but i work for verizon and you can take that phone in and they will swap it out for you just tell them you didnt do anything physicial to it damage wise and be nice to them because that was a defest on the original chocolate..
hav your phone serviced. that has an issue internal. they might have to replace some chips for that. youve checked the battery and still does the same thing.
I had the exact same problem and unless you know how to open up the phone and solder the connections back, which by the way are micro in size, the phone is pretty much dead. I had to take mine in and swap it out it still barely had a warranty. Try looking up a local electronics repair shop who might be able to help, good luck.
lg800 phone will not charge
