Question about Sharp EL-2196BL Calculator
Decimal point Just got this new calcuator. Can't get the decimal point set. I want to type in 1 2 7 5 and I want it to auto 12.75. HELP
  • Anonymous Feb 13, 2009
    Can't set the decimal to show 1060 as $10.60. How do it?
  • 3 Answers
You need to put your tab where it says K*A and set that to A (it is the 3rd set of buttons) and then you need to go to the 5th set of buttons that show F 6 3 2 1 0 and set this to 2. Hope that works :o)
Posted on Dec 16, 2008
How do i get 1.172 power .3
Hi there.
Type in the number 1 decimal point 1 7 2 then press y to the x button second row of dark grey buttons right on the left. Then type in 0 decimal point button 3 and press =.
Apr 14, 2014 | Sharp el-531x scientific calculator
Need to fix decimal point
Got to program mode press keys, [1], [2], [R/A]. This sets the decimal point for 2-decimal places.
May 28, 2012 | Royal 500DX 16-Department with 999 PLUS &...
Convert decimal fraction to binary
None of these solutions answer his question. When converting a fraction or any number with decimal places to Binary, the TI-89 gives "Error: Domain error." For example, entering .6875 [2ND][MATH][BASE][BIN] does not work. I haven't found a way to do it with built in functions. In order to do these types of conversions, I use the following method.
Convert: 0.6875 to Binary
- left of decimal is a 0, so write down a 0, then a decimal point: (0.)
- multiply .6875 x 2 = 1.375 left of decimal is 1, write a 1: (0.1)
- drop the 1 and multiply .375 x 2 = .75 left of decimal is 0. write a 0: (0.10)
- multiply .75 x 2 = 1.5 left of decimal is 1, write a 1: (0.101)
- drop the 1, multiple .5 x 2 = 1. left of decimal is 1, write a 1: (0.1011).
- since there is no more fraction, the final answer is (0.1011). Hope this helps.
Jan 27, 2012 | Texas Instruments TI-89 Calculator
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
May 23, 2010 | Sharp EL-501WBBL Calculator
How to set up four decimal point for TI-83 plus? Mine right now is 2 decimal point.
Do you mean four places behind the decimal point? Page 21 describes setting for fixed decimal point 0 thru 9 places to the right.
http://education.ti.com/downloads/guidebooks/graphing/83p/83m$book-eng.pdf
Nov 24, 2009 | Texas Instruments TI-83 Plus Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
Reset calcuator
try this, press shift mode, then line 10. It will make it permanent. the answer will always be in decimals. if you are using a casio with ES models.
Jun 14, 2009 | Office Equipment & Supplies
SETTING UP THE DECIMAL ON NEW 210 TM
Set the +43210F switch to + (or 2).
On some models it is A43210F, then use A (or 2).
+ mode will let you enter numbers (monetary) without the decimal point and assumes cents; 2 mode will just round to 2 decimals, but you must enter the decimal.
May 05, 2008 | Office Equipment & Supplies
My TI-89 cant do simple calculations.
You have to set how the calculator handles numbers. To do this follow these steps: 1. Press the 'MODE' button. This brings up the calculator's main settings page. 2. Scroll down until you reach a field titled 'Exact/Approx...'. This is the setting for how the calculator handles numbers, whether it will show the exact answer (which is usually in fraction format) or whether it will show an approximate number (which will be in decimal format). 3. Press the right arrow which will bring up the options for that setting. You must now choose between three ways of handling numbers: -'1:AUTO' will determine which type of answer the calculator will give based on what numbers you want it to calculate (e.g. if you want an answer in decimal format just add a decimal somewhere in your problem). -'2:EXACT' will automatically display all answers in either whole number format or in fraction format. -'3:APPROXIMATE' will automatically display all answers in decimal format. 4. After you have selected one of those options press enter one more time to get out of the 'MODE' dialogue and return to the 'HOME' screen. Now try a problem and see what happens. Personally I like using 'AUTO' because then I don't have to keep returning to 'MODE' when I want either or. Hope this helped, I had the same problem when I first started using the TI-89.
Sep 18, 2007 | Texas Instruments TI-89 Calculator
Sharp EL-2196BL Calculator Logo
755 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
