Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Heigth problem My refrigerator won't slide all the way in against the wall. Is there a way to adjust the heigth to lower it just a tad, a tad meaning like a quarter of an inch? Thanks, Diana
  • 4 Answers
You should never have your refer to close to the wall becouse it needs air flow to the coils under unit
Posted on Oct 17, 2008
How to trouble shoot a brush warning light
What color light are you referring to? If it is one of the green lights that is normal for the up and down adjustments. If it is the red one that is another issue. If it is the red one, what does it do while it is on? Does it flash or is it on solid?
Jun 17, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
Do I have to offset the "drop elbow" so the
yes move it 3 or 4 inches to either side o0f center at a heigth appropriate for your height about heart high.
May 20, 2011 | Moen 3867 Four Function Hand Shower With...
I recently installed a 32 inch LCD TV. The picture appears to be oversized and I do not know how to reduce the heigth and width.
You should download the user manual so you will know how to make the adjustment;
http://www.retrevo.com/support/Insignia-IS-LCDTV32-TVs-manual/id/8223ag521/t/2/
You need to look for 'ASPECT', 'P.SIZE', 'ZOOM' I.E. on the remote control.
Feb 18, 2011 | Insignia IS-LCDTV32 32 in. Television
How hard is it to remove the seat for transport in a SUV
jim not too hard unless its not been removed in a while. Unplug the joystick cable running to the rear of the chair pull up the seat release lever usually on the right side of the seat and twist and lift up on the seat at the same time hopefully the seat will lift right off. Now before you try all that remove the headrest from the rear seat and lift up on the seat adjustment lever and fold the seat back forward as far as it will go. Measure the heigth of the chair in that position and measure the heigth of your SUV opening if it is 3-4 inches lower then the chair should fit without having to remove the seat. You could also unscrew the armrests where they go into the risers at the rear of the seat and lay them on the back of the lowered seat back and drive the chair into the SUV using a ramp. This used to work for me when loading into a Jimmy SUV Hope this helps you
Nov 18, 2010 | Pride Jazzy Select 6 Indoor Power...
Starrett heigth gage instructions
Here is a link to starrett's how to read a vernier height gauge article
http://www.starrett.com/download/251_p122_125.pdf
Give them a call the parts department is very helpful and reasonably priced.
978-249-3551
Dec 27, 2009 | Starrett Measuring Tools & Sensors
Lokking to raise blade heigth. Is there something
they are 2 nuts that raise and lower deck one on each side turn up to raise it,, hope this help,, good luck
Aug 08, 2009 | Garden
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
