Question about Philips Magnavox Learning Universal Remote
Remote control unit does not turntv off or change channels!!!1 Does not control volume any more!!
I need to program the remote for my tv
Posted on Oct 04, 2008
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
Sony trinitron kv32-s15 remote willnot change channels, but, will change on/off and volume.Also, manula channel up/down willnot work
Try to change channels by manually entering the numbers on your remote. If this works then you need to reprogram your channels.
Aug 21, 2010 | Zenith ZN110 Remote Control
My control remote doesn't change channels. the sat button lights up in green and all i can do is change the volume.
Hi there! You may need to readdress the remote to the receiver. Just follow these quick steps to do so:
1. Access System Information screen and note the Remote Address
2. Hold SAT on the non-working remote until all lights on top turn on.
3. Enter a number between 1-15 and press #
4. Press record 3 times and the number should change.
Tommy Faust
DISH Network
Aug 11, 2010 | DISH Network IR Remote Control
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
No channel control knob on Sharp Linytron: 1993-Model 1 3SB50.
This set was a massively stupid idea and requires the remote control for everything. You'll need to buy a universal remote control, which should give you the basic functions (power, volume and channel control), but might not get you access to picture or sound adjustments. I don't think this set had any special features.
Mar 26, 2010 | Televison & Video
My remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Sony RMT-D155A Remote Control
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
New remote will control volume but not channels
Try a different code for the brand of TV. Use the manual to try the different codes available or visit the remote menufacturer's web site for a list of codes.
Jun 27, 2008 | RCA RCR311B Remote Control
Catv
try to purchase a new remote for samsung because all samsung remote is universal to all remote units.and there you can set the program.
Sep 04, 2007 | Samsung TV Remote Control
Philips Magnavox Learning Universal Remote Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
