Question about Brother Office Equipment & Supplies
Changed drum cartridge DR-520 in Brother 8065DN Instructions say to hold go button and there is no go button that I can see. with new drum in place it is still giving drum low mesg to replace. thank you
  • 170 Answers
Hi Kathleen,
  1. open the front cover
  2. press the clear/back key
  3. press 1 to reset
  4. close the front cover, pressing firmly on each side until they click into place.
Really hope this helps and if so please mark as fixya...
Posted on Oct 02, 2008
Dr 420 how install it
Fit the toner cartridge into the new drum, open the face/hatch of the machine and slide the drum/toner into the cavity. Push the unit all the way back until it is solid. With the hatch open (and power on) follow the reset instructions. For a printer find the stud that would sit under the "go" button when the hatch is closed, usually left side at the font. Press and hold until ALL the lights are illuminated then release. Close the hatch - job done. If the machine is copier/fax, press either the options or clear buttons. A message will apper in the LCD display "Change Drum" 1:yes 2:no (or something to that effect) - key yes, close hatch, job done.
Oct 29, 2013 | Brother Dr420 Black Drum Unit Cartridge
Get the most from Brother Drums and Toner - Stop Early Failures
Brother laser printers, fax machines and multifunctions all use a toner reclaim system. That means the used or left over toner (along with paper dust and debri) is recycled into the new toner cartridge supply. There is no waste section for the leftover toner and debri. This design is efficient however their are some short falls that you need to address. The toner cartridge supply is slowly contaminated with debri and dust that will send the cartridge down prematurely if your not using a good quality paper.
In addition, Brother Drum Units (ie DR-400, DR-500, DR-510, etc...) are expensive and suffer from the same premature failure problems. There is a charging brush and transfer roller inside the front top inside of the drum that drags on the drum surface to charge and discharge it properly for toner transfer. If you use poor quality the built up paper dust and debri interferes with this system and ultimately prevents it from working prperly. Here's a photo of a newer drum that failed due to the use of poor paper. Note the paper dust embedded in the transfer roller (top), caught up in the charge brush (center) and actually laying on the drum (bottom).
Here's a closeup of the charge brush so you can see the problem better below.
Below is the damage that bad paper caused. This DR-520 drum pictured is rated for 25,000 pages but due to low quality paper lasted just over 7,000. This was caused by a "Store Brand" paper.
Here below is a photo of the inside of a brother toner cartridge contaminated with paper dust and debri due to la ow quality super store brand paper. Note all the white paper dust in the toner.
To get the full yield from your Brother supplies, simply use GOOD QUALITY PAPER. STAY AWAY FROM STORE BRAND PAPERS as they go out on low price bid rather than to meet a tight quality standard. I would recommend a HP Brand paper as it's an "ALWAYS KNOWN GOOD" paper. The cheapest on the HP branded papers is HP Office and it works well.
Hope this has helped you understand the importance of using good quality paper in your brother machines. If you found this helpful, please rate it with a FIXYA as significant time and effort was used to help you.
Thanks and Happy Printing
on Aug 30, 2008 | Brother FAX-8360P Plain Paper Laser
I replaced my drum and the output quality is poor and light in areas
did you clear the required counters and run required procedures? If not the machine still thinks it has a old drum because counter was not cleared only way copier will know it has a new drum
Mar 23, 2012 | Brother DCP 8060, 8065DN, HL 5240, 5250DN,...
How do you reset the counter when you replace a drum unit?
In Brother DCP-8460 procedure to reset the counter is:
Open front cover a push "Clear/Back" button and on the display show "Replace or change the drum" just choose Yes and push "OK" button.
I hope I helped.
Feb 03, 2011 | Brother DCP-8065DN Black and White Copier
The scree reads change drum soon. what does it mean
The drum is the part of the unit that actually does the transfer of the toner onto the paper. Each toner cartridge does about 2,000 pages and the drum needs to be replaced with the ~6th toner cartridge change (varies with use). Order part DR-250 from Brother or any office supply place that would carry the part.
To replace (wait until print quality decreases or it reads change drum now and stops working). Turn off the unit and let it cool. Close the document tray and the extension and open the top cover. Remove the drum carefully and place it where the toner will not spill. Remove the toner cartridge (if it is still good) and set it aside to put in the new drum.
Wrap the old cartridge up and dispose of properly (not in the domestic trash). Keep the new drum out of the light (keep it sealed until needed) as much as possible. Insert the toner cartridge in the new drum. Then insert the unit into the Fax machine. (Hold by the handles) Close the top cover and the starter sheet should be ejected by the machine.
I hope this helps.
May 03, 2010 | Brother IntelliFAX 2800 Laser Fax
Dr-360 mfc drum reset
Brother MFC-7345n. DR-360 With power on and door open hold down the Clear/Back button. When asked new drum 1 for yes and 2 for no. Press 1 for yes to reset drum life
Feb 02, 2010 | Brother HL-2040 Laser Printer
Change drum
You need to go buy a Brother DR-350 drum unit cartridge. The drum unit is the thing that the toner cartridge (TN-350) clicks into. Pull out the drum/toner unit and separate the two halves. Place your TN-350 into the new DR-350 cartridge and put back in the printer.
Jan 18, 2010 | Brother IntelliFax-2820 Laser Fax
I have a new ink cartridge in my Brother HL5250DN...but the ink is coming out faded...could it be the Fuser?
Possibly, but it is more likely to be the drum (DR-520). Print a "settings" page (click GO button 3x). Page 2 should show the estimated life of the fuser and the drum so you can decide which one you need to replace.
Oct 20, 2009 | Brother HL 5250DN Laser Printer
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
1,007 people viewed this question
James Cagle
James Cagle
Jim Keysor
