WIFE WAS BAKING MANYD AYS, TODAY WHEN WE PRESS BAKE AND SET TEMP IT JUST SHOWS 100 DEGREES BUT WILL NOT HEAT UP OR KICK ON. I UNPLUGGED THE RANGE FOR 4 MONUTES, WHEN i PLUG IT BACK IN IT SHOWS A CODE 50 FOR A SHORTY TIME, THEN REVERTS TO THE CLOCK TIME. WONT KICK OVEN BROILER DOES WORK AS DOES GTHE STOVE GTOP, JUST THE OVEN WONGT CME ON ON??
You have a bad ignitor part number 74007498 and it's around 65 dollars.pull out the racks and remove the floor of the stove and you'll see the ignitor screwed to the burner tube,wet the screws with a wet paper towel,they will come out easier or if it makes it any easier remove the tube and then remove the ignitor.first start the stove if the ignitor glows but doesn't ignite the flame in 40 seconds or less it's bad,if it doesn't glow at all check it for continuity but it sounds like the ignitor is bad,if the new ignitor comes with wire nuts,cut the wires close to the body of the old ignitor,trim some of the wires back on the new ignitor and wire nut them together with the ceramic wire nuts,on some you can get the screws out of the ignitor,cut the wires close to the body,mount the new ignitor,trim back the wires on the new ignitor and wire nut them together and you're done,it doesn't matter how long the wires are just as long as the wire nuts are under the floor and away from the tube.it might help to remove the bottom draw to get at the wires,hope this helps and good luck.
