Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Record Changer Arm
The arm on my Wurlitzer One More Time jukebox is not operating. The carousel is spinning to the proper record selection, but the arm is not moving to pick up the record.
  • Anonymous Mar 30, 2014
    record carousel wont stop turning ready for record selection
    Champion:
  • Wurlitzer Expert
  • 211 Answers
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Posted on Oct 20, 2008
  • lesbear Oct 17, 2010
    Thank you davejuke solved my problem...Arm was not working - Gripper moter switch was in off position....XOXO
Wurlitzer one more time. no sound and record will not eject
There is a switch just under the tone arm. When the tone arm moves towards the centre it slowly pushes two copper strips together. When they meet it starts the motor to eject the record. If you can't Cancel the record with the cancel button then that is a different problem, otherwise you can adjust the trip switch by inserting a 7mm spanner down the hole to the right of the tone arm post.
Apr 30, 2012 | Wurlitzer Jukebox 1015 One More Time...
I have a Wurlitzer one more time. vinyl record jukebox.. I moved ( or turned) the turn arm forward to clean behind it and now the records will start to play and return to the changer. How do I adjust it.
Look up underneath the mechanism. You've moved the tone arm with respect to the bracket beneath it (which closes the trip switch). Select a record...turn the machine off...then look up under whilst someone moves the tone arm and you will see what it is attched to. If you are lucky you can hold that tight and gently move the arm back the other way a bit.
Jul 28, 2011 | Wurlitzer Jukebox 1015 One More Time...
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Hi, I have a Wurlitzer 3600 Superstar that I am working on. I am having trouble figuring out why the carousel won't stop spinning. It is looking for it's "Home" position, but won't stop. If I select a...
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
Oct 07, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1800 jukebox, plays record but at end the arm does not lift so record does not reject until I press the reset button and then it works.
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer model 556
Are you sure you mean 556? Sounds an odd model to me. The model number is on a black metal plate the size of a credit card on the back of the jukebox (usually).
Manuals can be found at www.victoryglass.com (USA) and The Jukebox Man in the UK.
Dave.
Nov 04, 2008 | Wurlitzer Jukebox 1015 One More Time...
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
May 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600
email me at philhemmings@hotmail.com so i can send you an attachment for the jukebox that may help you
Wurlitzer one more time 1015 flashign #8
It's the 'duck bill' bracket on the shaft near the gear box. On the others side of the white gears at the base of the tone arm. There's a white bracket that dips and clicks a microswitch when the gripper arm is over the carousel. It's come loose. Press it with your finger when the gripper arm is over the carousel and it will stop. Tighten it in that position..
Dave. The Jukebox Doctor.
Dec 29, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
197 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
