Question about Dryers
Tumble dryer drum wont rotate is it my belt .if so how do i replace it
My drum wont rotate tho it still heats up .is my belt needing replaced.if so how do i do this
  • 1 more comment
  • cleodancer1 Oct 02, 2008
    whirlpool awz7303
  • cleodancer1 Oct 03, 2008
    8575 730 15033
  • Rebecca Parks
    Rebecca Parks Mar 14, 2009
    Have a wp duet , lights come on, timer counts down, but drum doesn't turn. Help! Becca
    Genius:
  • 1,122 Answers
Yes it is the belt,what make and model number(inside dryer door or on it,let me know and we can go from there-mike
Posted on Oct 02, 2008
  • MIKE major Oct 02, 2008
    are you sure that is the model number?because i can't get anything to come up with that number,please check again and make sure it says model in front of the number-mike
  • MIKE major Oct 03, 2008
    I HAVE GONE TO SEARS .COM CLICKED ON PARTS PUT BOTH YOUR MODEL NUMBERS IN AND NOTHING COMES UP,IF YOU HAVE A TOP LINT SCREEN REMOVE 2 SCREWS ON IT PULL TOP FORWARD AND UP,REMOVE 2SCREWS ON INSIDE TOP FRONT , PULL FRONT UP AND OFF,PULL UP ON BELT TO SEE IF IT IS LOOSE ,LOOK UNDER DRUM AND FIND THE PULLY IT GOES ON,IF NOT A MAYTAG THE GROOVED SIDE OF BELT GOES ON THE DRUM,IIF YOU HAVE IN DRYER LINT SCREEN INSIDE IT IS BASICLY THE SAME ONLY USE A PUTTY KNIFE IN THE FRONT SEAM TO POP EACH CLIP,ONE ON EACH SIDE FRONT,LET ME KNOW HOW YOU DO-MIKE
Whirlpool duet 2004 model heats but wont spin
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Also check outvideos for other style dryers. If you hear the motor running but it does not tumble it is most likely the belt.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out.
Remove the belt.
Check for obstructions in the blower fan housing.
Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
Oct 21, 2012 | Dryers
I HAVE A TUMBLE DRYER BECKO DRVS62W THE BELT HAS SNAPPED HOW DO I REPLACE IT. THE DRUM DOES NOT ROTATE MANUALLY IS THIS ANOTHER PROBLEM OR WILL THE DRUM ROTATE ONCE THE BELT HAS BEEN REPLACED.
If this is an electric tumble dryer,
the way to replace the belt is from the rear of the machine,
remove all the screws on the rear silver panel, which gives you access to the internals of the dryer.
And yes the drum wont turn properly if the belt is broken.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Tumble dryer drum won't turn
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 06, 2009 | Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Ultimate care ii Dryer wont tumble
Belt,
Motor,
Door switch.
Remove the belt,
Check for obstructions in the blower fan housing,
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer wont spin
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Aug 27, 2008 | Dryers
Kenmore electric dryer
Belt
Motor
Door switch
  • Remove the belt.
Dryer does not tumble, but heats up
  • Remove the belt.
if this helps please vote me a fix ya
Jul 15, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
196 people viewed this question
Top Dryers Experts
