CANNON MP370 WASTE INK TANK NEARLY FULL - Office Equipment & Supplies
  • merlin333 Dec 23, 2008
    Hi. I have the same problem. The display alternately flashes that the Waste Ink Tank is Nearly Full. I do not have a clue what it is talking about. Any offers of help would bew graetfully received. Cheers Geoff
  • Anonymous Apr 14, 2009
    aiyak...i also got the same problem loo...how to reset waste ink tank hah?My end User(printer owner) alwaysz asking me..
What does this mean and how can I solve this please
Posted on Jan 01, 2009
Cannon mp 370 waste tank nearly full How do you clear this
This is a pair of sponge that absorbs excess ink after you print a page. You can get a service kit from Canon or just pull them out and rinse clean. Unfortunately they are 12x5cm and 20x5cm felt pieces at the plastic base of the printer (probably one on each side) and very difficult to reach. If you do get them out and rinsed clean, you can reset the counter for the waste ink tank.
The procedure:
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
I hope this helps.
(ink jet printers are really designed with the expectation that they will be replaced when this error occurs.)
Mar 30, 2010 | Canon MultiPASS MP370 All-In-One InkJet...
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
What does Waste Ink nearly full mean? Canon MP370
If you peel enough apples, and throw the "waste" apple-peel into the basket, eventually the basket gets nearly full, and must be emptied.
Similarly, if you print enough pages, some of the ink becomes "waste",
and that "waste-ink" goes into a small sponge-and-bucket apparatus.
So, take the printer to a qualified technician, and get the printer serviced.
Nov 23, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Waste ink nearly full LCD ERRoR on Cannon multipass F60 printer
HiHello try ths
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 17, 2009 | Canon MultiPASS F60 All-In-One InkJet...
A message saying waste tank nearly full comes up and i need directions to fix it?
Hello. this message indicates that the computer merely has to be reset [canon is hoping you will take your printer to them for a costly tuneup] here are the steps to reset your counter:
Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
Here is a link where you can download the entire service manual for $4.00. http://www.tradebit.com/filedetail.php/4546475-canon-smartbase-mp360-mp370-mp-360-370
Oct 13, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Error waste ink tank near full
This page gave me a solution, try it.
Let me know if worked for you as for me scoring this solution. Thanks
Jan 30, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Ink cartridge
The real problem is that the waste ink tank is nearly full
Correct code procedure for resetting the Canon MP370
Reset Waste Ink
By pressing the black button
with the star (in a
head ?) above it, followed by
scan, copy, scan
2) Select TEST MODE (press right
arrow button 13 times).
4) It'll now say "- 8-2 +" press
the right arrow key once
to get "- 8-3 +" Hit ok.
6) Press the ok key.
7) It should return to showing
the "8:
Printer Test - 8-3 +"
8) Press the [Stop/Reset]key -
black key with triangle and
circle on it –
key.
Good Luck and don't blame me if it
goes wrong !!!!
Now you can print again, but it has not solved your full ink-tank, that has to be solved in future.
Theo
Jul 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
My cannon mp370 keep coming up with waste ink near full
I think this one will help you
Reset Waste Ink
By pressing Menu, Copy, Scan, Copy, Copy
6) Press the [Set] key.
Jul 05, 2008 | Office Equipment & Supplies
981 people viewed this question
jasbo
jasbo
