Question about Epson Stylus Photo R320 InkJet Printer
Epson R320 Paper Feed Problem
Hi!
I have an Epson R320 that does not feed paper well at all. It doesn't matter if it's 20# copy paper or heavier weight photo paper. It seems to "try" to snag it so it will feed, but it just doesn't. I get the red light and "paper jam" error. I realign the paper, hit the button and sometimes it goes the first time, and other times I have to do that 2 or 3 times before it "grabs".
I am wondering if there are feed rollers or something that I could use some alcohol on to clean or what? If so, where are they located and what do they look like? I have about 1200 pages to print and can't keep jumping up every 2 or 3 sheets to realign it.
Help please? Thanks in advance for any help.
  • Anonymous Oct 05, 2008
    The same problem is happening to me only with 81/2 X 11 paper, plain or photo paper. 4 X 6 and 5 X 7 photo paper feeds ok.
  • KLudPen Jan 01, 2009
    Same problem....printer acts like it's going to feed the paper, but won't. I'm guessing their is an issue with the roller.
    New Friend:
Biggest POS in the world. Brand new and doesn't work right. Will never buy from this company again!
Posted on Nov 30, 2015
4 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: label sheets won't feed, jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Posted on Dec 22, 2008
  • 68 Answers
SOURCE: EPSON STYLUS C4OUX
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Posted on Jul 15, 2008
edandgreta
SOURCE: paper won't feed
My CX4800 developed the same problem. It was an excellent machine until then. I tried everything I could think of, and finally decided it must be the rather large feed in rollers at the right of the paper bin (one below and one above the paper) that had worn too smooth to pull the paper in. It works fine if I will give the sheet a "push" when it starts to go down - but who has time to stand there and push each piece in! It would really be nice if Epson would provide us with inexpensive replacement rollers and instructions for installing them. Guess they had rather we just buy a new printer - which I did, a CX7800, only to find that it will not take the heavy weight photo paper. :-(
Sorry I couldn't help more.
Posted on Aug 04, 2008
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus c68 paper jam
Hi Guest.
Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
R320 WILL NOT LOAD PAPER , ANY SIZE
Hi
Better get a new, call epson at 562-276-1300 so that you can have a discounted brand new printer from them.
Hope this helps
Nov 28, 2008 | Epson Stylus Photo R320 InkJet Printer
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Paper feeds through crooked and comes out crunched
Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
May 29, 2008 | Epson Stylus Color 740 InkJet Printer
Paper Feed Problem
I had same problem... eventually just started using 8.5 X 11 paper to print photos with smaller sizes.
Mar 30, 2008 | Epson Stylus Photo R320 InkJet Printer
Printing
seems that y´all experiencing various paper feeding issues
check first for recommended paper type
that printer should handle 4x6´s up to 8.5x11´s
and if it can´t feed a particular size - hardware issue & check your warranty status with the manufacturer
Dec 24, 2007 | Epson Stylus Photo R320 InkJet Printer
Paper jam
Well, if you could put that disengaged gear back all by yourself, then put a little "grease" or "oil" on the right side of the paper tray are mechanical levers or gears especially the one pushing the paper forward... when you're done.. printing goes fine again...
Oct 25, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
979 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
