Rancilio Silvia Espresso Machine
Problem for Rancilio Silvia Espresso Machine
Blowing the fuse in the
By bybrandy on Oct 02, 2008
Blowing the fuse in the kitchen when it's turned on.
Same Problem
Apr 14, 2009
-   We are having the same problem with our Rancilio Silvia.  It started tripping the circuit breakers and fuses in our kitchen after running fine for a little over 5 years. troubled in VA-   ch in va
Apr 06, 2009
-   I've had my machine for a few years, and this weekend it has started tripping the circuit. Won't work now, what gives?-   goofy66
Dec 25, 2008
-   My brand new Rancilio Silva trips my kitchen wall outlet circuit breaker when the brew button is switched on. -   Ritterview
Dec 08, 2008
-   Our Rancilio Silvia also trips our circuit breakers when turned on. I suspect that it has something to do with a thermostat because it first tripped just before I expected the ready heating ready light to illuminate.-   squidhudo
Nov 24, 2008
-   My Silvia all the sudden blows my kitchen fuses when I turn it on. It is 6 years old.-   julia65
Solution #1
posted on May 24, 2009
Not Rated)
bansheracer
Rank: Guru  Kitchen Appliances  Expert
Rating: 93%, 182 votes
Hi
When you blow the fuse your heating element is blown. The only fix is to replace the boiler. Sorry
Was this helpful?
Yes
No
Popular Solutions for Rancilio Silvia Espresso
Questions and Unsolved Problems for Rancilio Silvia Espresso
Do you recommend Rancilio Silvia Espresso Machine?
Answer
Answer
Reduced flow of hot water through the coffee brewing head and increased noise level from the pump. ... (More)
Answer
Can you supply a thermostat for a Rancilio Silvia? the one required is T3 in the wiring diagram, and... (More)
Answer
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been... (More)
Answer
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process,... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 04, 2008
My Sylvia started blowing fuses recently -- perhaps the fuses are weak. But I'd like to know.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rancilio Silvia Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
