Question about Nokia 6600
Dead water damage dead at first step it was turn off after exactly 32 sec then it was remained in pcb cleaner for 12hrs only for 1 day it works then after removing battery it was found to be dead
  • ellancey May 11, 2010
    post it now please.
Cleen the laqiar tiner of the boar of your c.p
Posted on Oct 17, 2008
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 | Cell Phones
Nokia C5 won't power on (only had phone for 1 month). Might be slightly water damaged due to my baby holding it with damp hands but couldn't imagine this would damage it? I've pulled the battery out and...
Please follow these steps. - Check the battery with a volt-meter, whether it has at least 3.2 V. - If its lower than that value - Give a Boost charge (Approx. 5V to the battery terminals) - Try to switch on the phone with a power supply - if the phone is not starting or dead just consult a technician - If the phone is restarting, it says it has remaining water drops inside - and the phone is RECOVERABLE.
Mar 07, 2011 | Nokia C5 Cell Phone
Screen remains locked on Blue background welcome screen when it finally comes up. Status light remains blinking green. Over the past 7-10 days it took several tries powering on then off before picture...
Tv manual PCB control buttons all work?Like power on/off,volume - + and chanels + - all work than it not the manual PCB board control IR is parts of this board.Not the IR problems,when tv is finally on the remote work fully everything buttons?No,could be remote control have problems.Tv might have DM power supply board problems.
Feb 08, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
My tv has no sound when you first turn it on you
U just have a flash of picture a few sec. Turn off on again,than sound remain?The 2 or 1 long LCD inverter board are dead.Tries the Websites like Shopjimmy.com,Ebay.com to buy those refurbishes long LCD inverter board for the replacement.
Jul 03, 2010 | Olevia LT32HVM 32 in. LCD Television
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Sceptre naga blue screen when tv on then turns blank, sound on
i have a secptre t v turns on for a sec and screen is blue then goes to blank screen can anyone help
Apr 18, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Fridge & Freezer not cooling
You will need to change the complete control pc board.
Mar 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice maker will fill after water line disconned@reconned in 12hrs.
When you installed the filter did you make sure to purge the filter. Meanins did you run water through the filter to make sure you have got all the air out?
Feb 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water damage recover MOTO Q SMARTPHONE Further assistance
oprn ur mbile circuit and remove battry and put them in sunlight not the battry okkkkkk
Nov 27, 2007 | LG VX6000
Nokia 6600 Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
