Problem with GE CleanSteel GSL25JFTBS
How do you test the defrost heaters
My unit doesn't go into defrost or defrost heaters aren't working
Posted by avatar on Dec 11, 2011
Solutions (1)
Best Solution
You would remove the rear panel on the inside of the freezer which would give you access to the evaporator coil. You would then need a multimeter and to be able to perform an ohms test on both the defrost thermostat and the defrost heater. Make sure that the unit is unplugged and both parts are disconnected entirely before peforming this test. The defrost thermostats usually read around .50ohms and the defrost heaters vary about the lowest I have seen is 21 ohms. Usual is around 25-28 ohms in most units. If you have any questions message me back.
Thank you
Rick
Add Your Solution
See all GE CleanSteel GSL25JFTBS Problems
