Hi. i have a loud sound from the fan of the dlp sumsung tv, seral number hlp5063wx/xaa, when i turn it off and on and sometimes the screen will go away but there is still sound... i need assitance.. thank you
    Genius:
  • 2,920 Answers
I got booted off line im sorry
Posted on Oct 02, 2008
MY TV STARTS EMITTING A BUZZING SOUND AFTER IT'S BEEN ON AN HOUR OR SO. It is a Samsung DLP model HLP5063WX/XAA.
Its likely to be the color wheel which when fails can do several things: A high pitched whine or what is often described as a fan like sound.
Since the set monitors the speed of the wheel if it slows down even a little image may look odd or dark.
you can at worst hear a grinding sound and it means segments in the wheel are shattered or missing
Good news is it is readily available and many average people can replace it---you tube even has video instructions for most of the Samsung models for this.
Only two models were made and Google the model number with Color wheel to locate the one your set uses.
Dec 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP hlp5063wx/xaa - Cycles through the warm up 2 times but does not turn on, then 3 lights flash on the front (2 green, 1 red) Bulb is new and looks good, fans seem to be spinning freely. Any...
If your having the "3 light" problem it could be an indication of a bad lamp however if there is a buzzing or a grinding sound it could be one of two moving parts. The color wheel or the cooling fan. I would go the cheaper route and replace the color wheel first since you say the fan is spinning. The thing is the lamp will not turn on if there is a problem with one of the other two parts. The motor on the cooling fan is too small for such a big fan so I would definately try it next. It's a big problem with the DLP tvs. good luck!
Feb 14, 2011 | Samsung Televison & Video
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Loud humming noise
Usually a humming noise is a transformer going bad.
Jan 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung HLP5063WX/XAA- 46 in HDTV DLP
that's a failure about to happen in your video control circuit board..you feeling like you want to dig into this yourself, or does this have a warranty
Jun 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Sep 29, 2007 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
