Question about Black & Decker String Trimmer Cordless 12" 18V
Black & decker (older) strimmer.
I can't get the cutter line to unwind after its worn down too short to cut.
Desperate for your help please
  • 659 Answers
The only thing I can think of its too heavy of a guage of line I would try a size down and make sure that when you wind it that its a nice and smooth transition in it so that nothing is over lapping and going to prevent it also if its done right and you have done it too tight this will also put too much pressure on the line and allow for it to get jammed inside once its being used because of the pressue from use.
Posted on Oct 04, 2008
Black decker troubleshooting
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
May 20, 2014 | Black & Decker Irons
Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Black & Decker Garden
How to restring a black & decker gl 565 strimmer
Hi Bill,
If you turn it upside down you will see the strimmer head. You should be able to remove the protective cover which will allow access to the string cassette. The rest is self evident.
Feb 14, 2010 | Black & Decker Garden
How do i replace strimmer wire on a black and decker 315
how do i replace a spool and line on a black and decker GL20 strimmer x
Sep 10, 2009 | Black & Decker Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Jun 01, 2009 | Black & Decker Garden
How do I rethread the cutting line on a black and decker strimmer reflex plus
take the spool out there shood be a I hole to push the twine throu tie a not that wont come out look for dirtion or arrow to wind it leave enough to sitck thru the side where the twine cuts push the spool up and lock it
Jul 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
114 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
