Question about Xerox Office Equipment & Supplies
XEROX WORKCENTRE C 2424 ERROR CODE 07.010.43:8288
    President:
  • 2,072 Answers
That code means the print head is not moving freely. There are 2 likely causes, some other less likely causes.
Most of the time the print head pivot block gets overflow ink from the catch tray built up in it.
That block is located behind the left cover, ( looking from the front) about midway back and on the lower portion of the frame. It is stainless steel and about 1 inch square. Check and see if it has ink built up in and around the block. You will have to pull off the spring assembly over it then remove and clean it and the print head shaft thoroughly. That is the most common problem.
The next problem is the print head wiper blade being stuck to the print head. That is caused mostly by power failures or the machine being shut off improperly. That would require removing the scanner assembly, the right and left covers, the back upper cover and the ink loader to access the print head/drum area. The blade can be gently removed from the print head, then you would run the cleaning mode a few times.
The process drive motor can cause that problem if mistimed or bad, but highly unlikely.
I strongly suspect the pivot block or a stuck wiper blade.
Posted on Oct 03, 2008
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
Printer error 07,007.40:80035
Xerox 2424 or 8400 series 07,007.40/49 is a process motor sequence error often caused by the printhead leaking wax on to the pivot shaft and bearing block mounted on the left side of the printhead unit, this stops the printhead tilting. Check for leaking wax around the silver block on the side of the printhead or around the waste tray, if wax gets into the tilt gear at the back of the waste tray slot, this is the error it shows.
Oct 24, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
I need to restore NVRAM from the WorkCentre 2424.
1. From the System Setup menu, go to Information --> Troubleshooting --> Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
If that doesnt work try below.
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads 'Beginning Service Mode Initialization'. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. You should find it in the function sub menu.
Jul 16, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
XEROX 2424 is printing in reverse order
Check your driver settings, in Layout option some people things that print in reverse order is going to print on both sides but its not. It wil print your job backwards though. So make sure you dont have that selected
Oct 20, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Scanner workcentre xerox C2424
Have you tried going to Xerox.com, click on support, then enter the 2424, then support again, then type in scanning? There is a lot of info there.
You can also call 1-800-821-2797 and ask for second level support.
Apr 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
248 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
