29 Other Users Have The Same Problem - Continued
Comment by james_maclac, posted on Mar 04, 2009
The flicker/snowstorm problem when playing game, watching a dvd and when in menu function, seems to resolve when not running 1080p. Go to Display Settings....HDMI and Custom to access resolution choice.
Comment by astrae, posted on Mar 04, 2009
I have a similar problem with an LG 42LG53GR. On 1080p i get a snowy effect in the background of the menus and while watching dvd's. Blu rays seem to play ok. One thing I have noticed is when in the PS3 menus the tv shows the signal as 1080P 50Hz, playing Blu ray movie it shows as 1080p 24Hz.
I occasionaly get a white flicker as well which basically covers the whole bottom half of the screen. (on 1080i and p)
I've ordered a component cable and see how that goes. Haven't contacted PS3 support yet.
Comment by zenoran, posted on Feb 26, 2009
I have the same problem... I haven't used my ps3 in a few months and just turned it on and did the update and now I have the flicker problem. Exact same symptoms as what I'm reading online but no one seems to have a solution. It ONLY happens on 1080p... 1080i is fine... I called tech support and they said they aren't aware of the issue but the only way to get it resolved is to send it in. So, they're sending me a replacement box and I get to wait 2 weeks for it to come back. :(
Comment by Ryan_Zman, posted on Feb 16, 2009
sethmeisterg,
Yes, I have the LN46A650 and have the same problem. The 4th side port is the onlp fix I can find to use 1080p. Blu-ray works great on the other 3 ports in 1080p but nothing else seems to work in 1080p on those ports.
*--> If you or any one else finds a solution to this 1080p problem please let us know! Thanks!
Comment by sethmeisterg, posted on Feb 14, 2009
I just got a Samsung LN52A850 and initially connected my PS3 (bought around July, 2008 in a MGS4 pack) to HDMI3 (on the back panel). I didn't have any problems...until today (about a week later). I started seeing brief flashes of snow and audio "static" when the PS3 was in 1080p mode. No problem at all viewing BluRays in 1080p (just watched House Bunny in 1080p without a problem). I was really scared that it was a TV problem, but thankfully I found this thread.
The good news: I tried HDMI4 (on the left side of the TV) and am not seeing the flickering anymore. I would *love* to know the root cause of this problem!
Comment by Ryan_Zman, posted on Jan 14, 2009
As I thought, there was no easy way to disable 480i when using the hdmi for the ps3.
But the side port is working god for now. I have had it set to 1080p for a while and also have yellow Dog 6.1 installed in 1080p.
Comment by Ryan_Zman, posted on Jan 13, 2009
Just contacted Samsung for my LN46A650 and they said to disable the 480i on the PS3. I am going to try this but if I remember the PS3 wont let you un-check the 480i box but I might be wrong. I will let you all know.
Also, I plugged the PS3 into the side hdmi port on my tv and 1080p seemed to work great last night but I did not try it for very long. No idea why this would fix it but it seems to be a temporary fix.
Comment by junglekng, posted on Jan 11, 2009
HyperRon, You are right. Actually the solution I described earlier (remove 1080i from list of resolutions) did not resolve. The problem still persits but in a different way.
Every 5 Sec, I see my screen display going BLACK. This happens at start page,XMB, internet browser except while playing blue ray disks. It definately is not HDMI, HDCP handshakes(which happen at start)since its taking 1080p from blueray correctly.I believe that this is a firmware bug with this model. May be from core OS display routines.
Here is what I have.
firmware: 2.53 (may be I should not have updated to this version).
Model - CECCHL01 (from serial no) 80GB
Seriously, Sony Tech Supports SUCKS! I think they are just trained only on how to tell customers to unplug cables, and everything and reset/restart systems. The person is asking me to use component cables., Well, duh,!!...do you think we are fools using HDMI?OH..morons....Wait till I get a good lawyer for a class action lawsuit!
Comment by HyperRon, posted on Jan 11, 2009
I tried setting the display settings to everything but 1080i and I still have the issue. I have an LG LCD (52LG70) and LG's tech support swears it's the PS3 since it will play blu ray movies at 1080p without any issues. Sony finally told me there's probably something wrong with my PS3 and to take it back to the store. They told me this after almost 2 hours of testing/resetting/changing cables. So, I'm going to take it back tomorrow.
I tried the following cables:
Rocketfish PS3 8 ft HDMI
Monster PS3 HDMI
Phillips HDMI
Premium brand HDMI from HHGregg
Comment by junglekng, posted on Jan 10, 2009
I had the same problem. Samsung LNA52650 (1080p) with ps3.
But I have found a temporary solution. You can select the display settings from PS3 menu as follows -- 480p, 720p, and 1080p only (no 1080i) . This solved the issue. I see no flickering. But, not having 1080i means we need to switch whenever any game/video/ etc comes in that max resolution.
I am thinking it is a software/firmware issue that sony should release an update for. suprisingly, the tech support does not even acknowledge that they know/aware of this issue/received complaints from anyone.
Frankly. Sony Tech support is the worst.
Please update if that sol works for anyone.
Jungleking
Comment by craigmeakin, posted on Jan 07, 2009
i have the same problem, i have a 42 " LG, as everyone else has stated on 1080p i get snowy and flickers, whilst blue-ray DVD is playing i get great quality as you would expect but no problems, it just flickers and snowy on the start up screen when i switch my ps3 on. which is highly annoying, but putting the output setting to 1080I the quality is the very same has the 1080 P, the Blu-Ray are the same, i don't lose sound or quality of picture go down at all... it's just the same.
but if i thought the 1080I wasn't has good i would just switch the 1080P when playing games and Blue-Rays. but it doesn't seem to me that it's any different in quality or sound!!!
Comment by Ryan_Zman, posted on Jan 05, 2009
Same *** all others, Have a LN46A650 Samsung and a NEW PS3 from sonystyle.com (1/3/09) connected through a 6ft Monoprice HDMI cable. 1080p does not work at all or maybe for 2 mins at most. 1080i works great!
I played a Blu-ray when my PS3 was set to 1080i and my tv said the BD was playing at 1080p? So guess I will just run 1080i until SONY fixes the problem!
Comment by gangemcs, posted on Jan 04, 2009
I have exactly the same problem with my 42" 1080p LG TV and the PS3. It flashes when I select 1080p and the resolution BUT is fine with 1080i.
If you have any solution to this annoying problem then please email me at
gangemcs at gmail.com
Thanks,
Chris
Comment by masouds428, posted on Jan 04, 2009
I have the same problem, although I did not try switching to 1080i, I mean c'mon, I want the FULL HD experience. I have the 32LG70, which is the same TV, only 10 inches smaller. I'm using my PS3 with a MediaBridge HDMI cable, and I get constant flickering on the TV, and its not the cable or the TV since I'm using a cable for my Xbox 360 as well. I sent an e-mail to the LG customer service, and I am waiting for a reply. The live chat ould have been helpful, but they are offline right now. Please help!
Comment by nikoo83, posted on Dec 28, 2008
I have a similar issue, but with a JVC LCD 42S90 HDTV. 1080i: perfect. But when PS3 is set to 1080p, the screen flickers. Suggestions are very welcome.
Comment by HyperRon, posted on Dec 27, 2008
I have the same issue. I originally had a monster ps3 HDMI cable but, replaced it with the rocketfish cable the other poster suggested and still have the issue. I've tried 4 different cables and everyone has the same problem.
Comment by Obsieian254, posted on Dec 24, 2008
I had the same problem with my brand new LG 1080 42" screen tv, I bought a cheap HDMI cable phillips brand and had the same flickering while trying to play the blu ray or while in the menu. I went and bought another brand HDMI cable Rocketfish HDMI Digital Audio/Video Gaming Cable for PlayStation 3 and it cleared up the whole problem for me. I dont know if its just a fluke but no more flickering just perfect picture. This wasn't the most expensive cable it was 65$ here in the states, so maybe if it worked for me it might work for you guys
Comment by E-N-I-G-M-A, posted on Dec 14, 2008
Following on and in response to the solution 3 posted....
I havelooked at component cables and all my investigations tell me thatwhilst component cables can carry a 1080p signal, the actual connectionpoints (AV points) will not pass through anything greater than 1080i.
So really hooking up a component cable is same as setting the HDMI output to 1080i, which works fine anyway.
Thecurrent workaround I am using is to go to the HDMI settings, turn on1080p when i want it.... and if the confirmation screen is flickering,click back, then select it again. After a couple of goes it willpresent a picture the is stable, and remains so for watching blue-ray1080p movies, or playing 1080p games.
However when you exit backto the XMB menu or restart the system, it generally starts flickeringagain (and set it back to 1080i until I want 1080p again)
I havealso posted my issue on the PS3 forums and have had some responses...all of which don't resolve this issue - link attached for reference.
http://community.eu.playstation.com/playstationeu/board/message?board.id=bANZ_announcements_help&thread.id=1285
I have looked at component cables and all my investigations tell me that whilst component cables can carry a 1080p signal, the actual connection points (AV points) will not pass through anything greater than 1080i.
The current workaround I am using is to go to the HDMI settings, turn on 1080p when i want it.... and if the confirmation screen is flickering, click back, then select it again. After a couple of goes it will present a picture the is stable, and remains so for watching blue-ray 1080p movies, or playing 1080p games.
However when you exit back to the XMB menu or restart the system, it generally starts flickering again (and set it back to 1080i until I want 1080p again)
I have also posted my issue on the PS3 forums and have had some responses... all of which don't resolve this issue - link attached for reference.
Comment by vino42, posted on Dec 14, 2008
I also have this same problem. Using high end HDMI cable (Monster Ultra 800). Brand new LG 60 inch plasma w/1080p capabilities and have the same results on my LG 42 inch plasma. When I set to 1080p on the setup screen the test display screen looks snowy with a green color and flickers and sound pops and cracks. 1080i works perfect. I have yet to meet someone that has true 1080p working properly. This has to be a PS3 issue.
Comment by tkimdds, posted on Dec 01, 2008
I have the exact same problem. 1080i works fine but the menu screen on the PS3 flickers on occasion when 1080p is used. I've bought a Monster HDMI cable and the problem seemed to decrease a bit but it still exists.
Comment by stentme1, posted on Nov 28, 2008
snow on 1080p not 1080i with sony large lcd display. expensive professional HDMI cables. any ideas?
Comment by Guest, posted on Nov 06, 2008
Same problem here.And its really annoying
Comment by E-N-I-G-M-A, posted on Oct 14, 2008
I also have a new LG HDTV (47LG70yd) and have the exact same experience - got TV in early September 2008.
I have tested with new cables (3-4 HDMI cables of varying quality), a different Ps3 hooked to my tele (same problem), my ps3 on a mates Bravia HDTV (no problems). I have also tried everything the LG techo's suggest, including turning off the 'tru-motion', connecting with AV cables first then manually changing to HDMI.... nothing has worked for more than a few minutes, and as soon as the PS3 is powered down, it will re-occur when turned back on.
I have had the TV replaced initially when i first reported it, and LG techo's come with a software update for the tv later.... all to no effect.
Only happens on 1080p setting... all lower resolutions work fine.
PS3 support tried telling me my TV wasn't full HD (rubbish it definitely is), and from looking on net and own research it seems to be a HDCP handshake issue (I hope i got the acronym right ... I'm not expert)
The only fix I have at the moment, is to remove the HDMI cable, wait a few secs and plug it back in .... 50/50 it works, but as soon as you enter a game/movie and return to the XMB menu, it happens again. Also if you reboot the ps3 it will come back.
It is frustrating to spend so much money on a HDTV to have it not work as expected, and both Sony and LG seem unable to say definitively what the issue is, or how they are going to fix it.... and get impression it isn't a high-priority for either :/
SUMMARY OF MY ISSUE: Snow and flickering when 1080p resolution is set. Occasional sound drop out. At worst screen will go blank for a few seconds and return. Mainly on XMB menu, but have experienced a flicker about once every few minutes when watching a blue-ray movie, but not to the extent it happens on the XMB menu.
