I have a Mitsubishi DLP Projection TV WD-73727. After warming up within 15 minutes the reds start fading to pink and the light areas appear blotchy and washed out. As time goes by it gets to where the picture is unwatchable. Faces and skin are a pinkish purple and backgrounds have a greenish tint to them. Also get some flashing on the right side of the screen after long warm up. Had a local country TV Tech come in yesterday. He took off the back and vacuumed everything within reach. He removed the box containing the circuit board and checked all the connections, unplugged them and plugged them back in. After a $100 bill it still does the same. he thinks? it might be the power supply or the main circuit board. Both I understand are very expensive but I would like input if others have had this same type of problem before I start laying out a lot of bucks. He thought at first it was the color wheel but he thinks now that the problem is elsewhere. Thanks.......Don
SOURCE: flashing power light
you need 4 caps in you dm module they are 1000 mf @35volts
Posted on May 25, 2007
  • 4402 Answers
SOURCE: mitsubishi wd-52525 no picture or sound
replace DM
Posted on Jan 23, 2008
SOURCE: Mitsubishi WD-62525 DLP has no picture
the lamp went out in our wd-62525. I replaced it and cleaned the filter, now it makes a strange noise every few minutes and the picture gets distorted, then it's fine.We have had this set for only 16 months and have had to replace the mother board. What do you think the problem may be?
Posted on Feb 18, 2008
  • 146 Answers
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Posted on Nov 20, 2008
SOURCE: locating my color wheel in a sharp xr-30x dlp prokector.
Hope this reaches you in time.
1st: Turn the projector off, but leave it plugged in.
Then do the following......
Hold down simultaniously :
Help/Menu button, Enter button, and down arrow button,
Then while holding down all 3 buttons.
Press the Standby/On button
Once the projector turns on let go of the buttons, the press Enter button again and you should see a message in bottom left corner that says "Lamp has been reset to 000000"
Posted on May 15, 2009
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
Aug 19, 2009 | Mitsubishi WD73727 73" HDTV
Distorted colors on my mitsubishi wd-73727
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Apr 02, 2009 | Mitsubishi WD73727 73" HDTV
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 73727 73in
Contact Mitsubishi with the proof of this and demand a new TV set. Maybe it is the service shop causing this, your warranty should also be extended for the time you were out of the use of the TV set while waiting for parts. If this does not work, the state attorneys office should be able to get you a new set or at least this one repaired. Good Luck
Sep 26, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
