Question about Little Giant 10 Cia, 1/2 Hp, 83 Gpm Automatic Submersible Sump Pump 10' Power Cord
Five second delay with pump
Pump only runs five seconds then stops for five seconds.then five seconds later starts again,there is always a five second delay,it has been doing this all night and still this morning starts and then stops every five seconds.
last night was the coldest night we have had this fall around 40 degres
not sure if that had anything to do with it.
any help would be greatly appreciated
  • 15,935 Answers
Check the intake of the pump. It may be clogged with sludge or debris.
Posted on Dec 22, 2008
Hobart champion 16 I start the engine and it runs for five seconds and stops. I start the engine again it runs for five seconds and stops. What is wrong
Hey Joe, Sounds like a fuel starvation issue... the needle/seat/float that controls the flow of gas into the carburetor is probably sticking and letting a TINY amount of fuel in the carb,, running the engine burns it dry too quick and quits... takes a few minutes for it to refill, then you start it, and run it dry again,, (repeat-repeat-repeat).. sound about right?? Take it to any GOOD small engine mechanic... they can clean and set the carburetor...
this is no biggie.. just very aggravating..
Good luck! .please mark as helpful...
Sep 24, 2017 | Hobart Welding Tools
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
2006 ford five hundred headlights brighten every 5 seconds
Sound like a bad ground somewhere but it is strange its every five seconds. See if you can hear a relay clicking somewhere under the hood or dash.
Dec 14, 2013 | 2006 Ford Five Hundred
I love my bc796d and i have had it for about 4 years? My question is concerning the delay when scanning channels and i always keep it on 4 second delay. I would like to have it delay longer and thats where...
Setting DELAY for All Search Ranges
You can set the scanner to have a delay after the end of a transmission before searching
resumes. This slows searching, but helps you prevent missing replies on a frequency.
1:SERVICE OPTION → :CHAIN SEARCH → 3:DELAY
1:NONE
The delay is turned off.
2:1 SECOND
The delay time is 1 second.
3:2 SECONDS
The delay time is 2 seconds.
4:4 SECONDS
The delay time is 4 seconds.
28
5:INFINITE
When the scanner stops on a transmission, you must press RSM to resume
searching.
6: -2 SECONDS
The scanner only stops on transmissions for 2 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 2-second pause.
7: -5 SECONDS
The scanner only stops on transmissions for 5 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 5-second pause.
8: -10 SECONDS
The scanner only stops on transmissions for 10 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 10-second pause.
May 14, 2010 | Uniden BC796D Base Scanner
2000 volvo s80 ran out of gas put gas in but it wont start
Turn the key to full power (but do not crank the engine). You may hear a high pitched whine from behind you - that's the fuel pump running. Leave the key on for about five seconds, then turn it off for a minute. Turn the key on again for another five seconds, and off for a minute. Then turn the key on for five seconds, and then crank the engine.
If your car ran out of gas, you need to run the fuel pump this way to get fuel up to the engine again - all the lines from the tank to the engine are empty, so the pump needs to run to fill them.
If this doesn't work, it's possible that the fuel pump is vapor-locked and will have to be replaced. Some cars are more susceptible than others to this type of failure.
Dec 05, 2009 | 1999 Volvo S80
Engin light is on how to check codes
To check for trouble codes turn the ignition switch to run for three seconds (one second pause after the fuel pump stops running) and then turn the switch back to off for three seconds. Repeat this process again. Now turn the switch to ignition and wait for about 8 seconds and the check engine lamp will start flashing the codes. If there are codes present the light will flash rapidly (about three per second) then there will be a 2 second pause with the lamp off. The lamp will then flash one or more times to indicate the first digit of the trouble code. It will be on and off for about 1 second. Count the number of times it flashes for the first digit of the trouble code. Then there will be about a 2 second delay then will flash again for the second digit. After flashing the second digit there will be a 2 second delay and additional trouble codes will be flashed. Write down the numbers and when they start repeating themselves the trouble code transmission is completed. All trouble codes consist of two digits.
If the lamp flashes only the 3 flashes per second there are no trouble codes present.
If there are codes present, let me know and I can advise you of their meaning.
Oct 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
Trane air handler cycling rapidly
Depending on the age of your Trane unit. The fan relay has a time delay. This is a solid state board on the relay. Most of the time they stick on or off. Check for loose wires. But start with relay.
Jun 03, 2009 | Heating & Cooling
Running problems
I am not completely positive that this is your problem but one thing to try when it starts cutting out is to loosen the fuel cap. On a lot of 2000 through 2004 Harleys the vent in the fuel cap gets plugged up and creates a vacuum not allowing the fuel to flow to the carbs. If this doesn't help run the trouble codes to see if there is a ECM related problem. To access the codes, turn the ignition on for about 3 seconds (one second after the fuel pump stops running) and then turn the ignition off for 3 seconds. Repeat this, then turn the ignition on and the codes will flash on the check engine light after about 8 seconds. The first series of flashes (about 3 flashes per second) are intermission flashes then there will be a 2 second delay and the first code will flash. If the first digit of the code is 1 the light will flash one time and then there will be a 2 second pause before the second digit. There will be a 1 second delay between flashes for a digit of 2 or more. All codes are 2 digit codes. For example, 11 would be throttle position sensor, 12, barometric pressure sensor, 14 engine temperature sensor, 15 intake air temperature sensor, 16 battery voltage, 23 and 32 fuel injector, 24 and 25 ignition coil, 33 fuel pump relay, 52,53,54,55 ECM failure, 56 crank position and cam position sensor timing.
Hope this helps.
Apr 11, 2009 | 2003 Harley Davidson FLHTC Electra Glide...
Little Giant 10 Cia, 1/2 Hp, 83 Gpm Automatic Submersible Sump Pump 10' Power Cord  Logo
405 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
