Question about GE Spectra JBP78 Electric Kitchen Range
Burners, oven will not heat, all lights work
Have a GE JBP series range--the "burner on" indicator lights work, and the oven light comes on when you open the door, and the clock works, but neither the burners nor the oven heat up. Is there a "heating element" type device that might be replaceable, or is the stove junk now? Thank you!
  • 1,543 Answers
Sounds like you are only getting 120 volts. All heating elements require 240 volts to operate. Start by taking the covers off the back of the range and looking for loose or burnt off wires. Look first at were the range cord connects onto the range. If all OK with range wires, check wires inside range receptacle (where the range cord plugs in) and also the connections on the household circuit breaker or fuses. If you use a meter to test for 240, you may see it, but if a connection is poor, it may not be good enough to supply the required power.
Posted on Oct 02, 2008
Burners work oven wont light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
dhdg
May 15, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
GE Model #J TP30B0M1BB Oven The oven stopped heating up on either bake or broil. Light and display are still working
Check to see if 2 of your range burners have failed too.  It would indicate that your breaker needs to be turned off and then back on to get 240 V again.  The panel and 2 burners will work on 120 V just fine.
Nov 10, 2009 | Ovens
Heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
Oven and lights stopped working
is it the indicator lights at the top or just everything in the oven that is not working??
If it is just the light in the oven and the oven not heating then you are having a problem with your control board.
Jan 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Top burners and oven don't heat up enough-GE Spectra
the stove it's only getting 110 volts, that's what happen when it does not get enught power.
Dec 03, 2008 | GE Spectra JBP78 Electric Kitchen Range
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Model JBP79 FFFcode
FFF Control Error, Failed EEPROM Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
Nov 12, 2007 | GE Profile Spectra JBP95 Electric Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
354 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
