Question about HP Office Equipment & Supplies
Printer will not work it said to replace dimm1 what does that mean?
    Sergeant:
  • 268 Answers
It means you need to replace the memory chip inside of the printer...which requires taking the printer apart and messing about with it....your best bet is to call a service technician to look at it and take care of the job.
Posted on Oct 02, 2008
I called acer support and they said dimm1/dimm2 module organization is a hardware issue and can't be fixed without buying new parts. Is this true?
Hi Friend,
1st what is the issue ?!!!
2nd if its in warranty they can replace it for free otherwise you cant repair it and you should replace it with new part but first you must confirm if both modules not working properly.
Thanks,
Jan 24, 2018 | Acer Computers & Internet
Error sortout
Conduct the following setting.
[Service Mode] ? [Memory/HDD Adj.] ? [Memory Check]
? [Detail Check].
When "NG" is displayed, replace the appropriate memory or
PWB.
WORK0: DIMM0
WORK1: DIMM1
FILE0,1: MFP board
Sep 28, 2016 | Konica Minolta Bizhub C360
Alert ! unsupported memory configuration please p;pulate DIMM1
If the computer was working well and this error popped up, then the most likely issue is a bad memory module, most likely in the DIMM1 slot. If this occurred as a result of a new build or an upgrade, then there are other possibilities. Mainboards are particular in many cases where memory modules can be installed and in what groupings/types/speeds can be mixed and matched. The problem could be as simple as removing and re-seating the memory module in the DIMM1 slot (the slots are usually marked on the mainboard). If there are multiple memory cards installed, try rearranging them, or even removing all but one at a time to try to determine if there are any bad ones. If you are using one at a time, they usually have to be installed in the DIMM1 slot (but not all mainboards require this). After you determine if there is bad memory and which one is bad, you can either replace the bad module, or operate the unit with the remaining good modules, although performance may suffer slightly. The last possibility, and the worst one, is that the the DIMM1 slot on the mainboard is bad. If that is the case, and if you cannot operate without a DIMM in slot 1, you will need a new mainboard or new PC.
Apr 20, 2016 | Computers & Internet
in computers there are many kind of rams a big problems of ram which users are always face is buss speed different. we cant run all type of bus speeds of ram on our computer please replace your ram with the higer bus speed and run it.
and pull out your one ram from your ram bank. i mean to say decrease your ram speed.
Jul 16, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
At starting windows Alert ! unsupported memory configuration please p;pulate DIMM1 (desktop dell optiplex gx 755)
it means the dimm or ram which you plug in your computer is low buss speed so please pull out your ram for pull it out follow these instructions.
first of all open your computers shutter
now you will see the white black or brown long slods on *********** bord
on that slod you will see that the ram or dimm is pluged pull it out open it clips it will out automatically and replace it with the new one of higer buss speed. then start your computer . you will run your computer smoothly thanks
Jul 16, 2011 | Computers & Internet
The printer says memory failure "Replace Dimm1"
Dimm1 refers to the Memory module installed in Dimmm1.
It looks like a RAM module that is found in a computer.
In your case you may be able to solve the problem by ensuring that the module is making good contact, push it in.
You could also try removing the module and cleaning the gold finger contacts with tissue paper and then reinstalling.
If all else fails you will need to purchase and install a new Memory Module for your printer.
See the manual in this regard!
Take care!
damnor01
May 05, 2011 | HP LaserJet P3005n Printer
Unsupported memory configuration.please populate dimm1
open it up ..and see what is wrong with the first slot of ram memory ...if the inserted module is not working ...than remove it ..(to check if it works just leave it by itself and try to start the computer ..) anyway ..if there isn't any module in the first slot ..than move one from the last slot ..I mean mount the modules in slots from number 1 to ...as many you have available ...After finish ...restart ..press delete button right the way to go to bios settings ...and in here ..look for optimal factory default settings ..and engage them by selecting with arrows..and enter..and confirm with enter (Y)
to save settings before exit ..press F 10 ..and enter ..
This will assure the ram configuration ...in the correct way ..
Please read careful ..and ask if you do not understand something ...and also ..please rate my answer..cause it helps with my rating and activity on the site..
Feb 14, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Mem test fail replace DIMM1
This error indicates that either the formatter has failed, or if you have additional memory installed it is bad.
Dec 06, 2010 | HP Laser Jet Printer P3005dn
Error: Mem test failed; Replace dimm1. What does
hi it means that you have to replace the memory in the printer.
Jul 20, 2010 | HP Color LaserJet 3500 Printer
Please help me. I need xfx dimm1 display and audio drivers. regard Jamshed
Even though its not clear what you are actually talking about, because you didnt provide the details of you system, whether it is a laptop or a desktop and its Model number ('cos u just said xfx dimm1')..., but I would like you to try out these site to search for and download your needed drivers.
www.opendrivers.com or
you can also try out
www.laptopdrivers.com or
www.drivershq.com.
Hope this helps.
Goodluck.
Jun 05, 2009 | Intel Core 2 Duo E8400 LGA775 3.00GHz 6MB...
59 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
