Sky Remote Code
Has anyone by any chance ever find out the correct Sky remote code for the Technosonic 26" LCD2603ID TV
I have tried lots of codes, bought a Rev 8 remote and processed numbers until my fingers are sore and I've got a headache. I've searched high and low on the internet but nobody can confirm either the code or the true make of this TV. I have even rung Customer Services at the various Vendors of this TV such as Tesco but to no avail.
If you can help I would be obliged
Regards
Derek Orton
  • toad45 Oct 15, 2008
    Technosonic 32 inch
epik559
  • 44 Answers
SOURCE: code number for sky remote
Call the manufactor of that remote and ask for Funai remote codes.
Posted on Jan 03, 2008
SOURCE: Sky remote codes
0065
Posted on Aug 27, 2008
SOURCE: BOUGHT SAMSUNG LE40A656 LCD CAN,T GET SKY REMOTE TO WORK
I tried the closest model no. in the Sky list in the system setup, I think the code was 0840. Cover the front of the remote and press TV, then press red & select button until the remote led light blinks twice, key in the code 0840 and then press select.  Try the volume button and this should work.  If you get stuck go into interactive and system setup and select setup of sky remote and it gives you a list of makes and models, this is the closed one to the LE40A656 and works with mine.
Hope this works for you.
Posted on Jan 28, 2009
SOURCE: Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
Posted on Feb 16, 2009
SkyGuy08
  • 27 Answers
SOURCE: sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Posted on Apr 04, 2009
Sky remote code for my bush lc-46gl12f tv I've tryd all of sky's codes and no luck please help
try this...press TV on your sky remote now hold select and red button until it flashes tvice,now enter this code....1430...after u enter that code it should blink twice again,now press standby,if it turns your TV off,press select to save these settings, it will also control your TV volume...Let me know if this helps
Feb 09, 2013 | Televison & Video
Sky remote codes for television model 42PF9631D/10
Hi
The correct code (or whether there is a code at all) depends on which version of the Sky remote you are using. The version number of the remote can be found on a sticker inside the battery compartment. If you have "RC1600/00" "Rev 4" or "Rev 6" on the sticker, then it's unlikely that it will work with your TV, but please read on as this isn't always true.
If you have a "Rev 8" remote then it's more likely to work with your TV, however, according to Sky, you will need to buy the new "Rev 9" Sky remote:
http://www.thedigiboxshop.com/sky-hd-remotes-sky-hd-remote.html
If buying one, be sure to check the button for the "Rev 9" version ( £0.85).
The actual code for your TV model is: 0718
I suggest you try the above code regardless of which version of Sky remote you have as Sky's information is not always accurate. You can also try these generic codes for Philips TVs:
0584, 0266, 0065, 0749, 1679, 0199, 0679
Again, try these with whichever version of the Sky remote you are using. There is a good chance that one of them will operate the volume and power functions on your TV. If none of the above codes work, then you will probably need to buy a Rev 9 remote.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
Could you tell me sky remote code for technika model 22-220
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says REV 4, REV 6, or REV it might work with one of these codes:
1177 or 2011
However, according to Sky you need the VERY latest Sky remote to control the Technika 22-220.
Personally, I thought REV 8 was the latest version, but it seems they have a newer one. I can't find any reference to it or anyone selling it though - even Sky themselves.
Try the 2 codes above and report back.
Oct 14, 2010 | Televison & Video
Code to enable sky remote with Digitrex TV
I have a digitrex tv with remote indicating on reverse serial numbers( CTF2685. CTF3271. CTF4071) which I couldn't turn the volume up or down change the channel etc but this worked for me 1.press the tv button
2. Press select and the red button at the same time for 2 seconds the light will blink twice.
3. enter code 2193 and the light will blink twice. Problem was then solved sky remote fully functional hope this helps people out sure helped me thanks guys
Mar 08, 2010 | Televison & Video
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Jan 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Sky remote not controlling volume
press tv on the sky remote
press and hold select and red until the LED blinks twice
enter the code
press select
it should work if you have the correct code
Dec 31, 2008 | Big Button TV Universal Remote
Televison & Video Logo
Top Televison & Video Experts
