Question about Refrigerators
New door required for freezer compartment to Kuppersbusch integrated fridge/freezer Model No: IKE 318-6. Bristol area supplier/fitter preferred.
    Genius:
  • 1,550 Answers
This link will be helpful to provide you the door for your freezer
Door for kupersbusch
Thanks for using Fixya
SAM ANDERSON
Posted on Oct 02, 2008
    Guru:
  • 1,894 Answers
Here it is
www.kbbappliances.co.uk/acatalog/IKE_318_6.html
  • dewan nafees ahmed Oct 02, 2008
    but fitter cant be arranged by us.
    you yellow pages must help you with that
I live in York WA and require a Bosch Intelligent Frost Free 40 fridge/freezer.. fridge door seal. Would like to know how much... and where to purchase? Gail
you can go online and search for the part using make and model their are 100s of appliance parts suppliers or go to bosch site and either order or request a supplier by you
Apr 23, 2017 | Bosch Refrigerators
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
HI! I broke the handle on the door at the freezer. Can that be fixed? If not where can I buy a new door? The model of my fridge is: Kuppersbusch Integrated Fridge- Freezer Modell: IKE 318-6. Thank...
We were able to purchase a replacement handle for our freezer from RepairClinic.com . You'll need the model #, Serial #, and date of manufacture.
Jan 18, 2011 | Refrigerators
We have a GC2227DEDB fridge freezer it has a waterleak any ideas
geohgh -- GC2227DEDB Kuppersbusch/Maytag Refrigerator/Freezer - If in high humidity area then water condenses between the outer skin and inner skin. Builds up and then releases once surface tension limit is reached. Releases about 250ml to 500ml or more in some cases, directly onto the floor. Solution is to make or have made a Stainless steel tray to fit under the refrigerator. Motor heat then evaporates the water.
Sep 07, 2010 | Kuppersbusch K EGS 304.0 J Stainless...
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
Freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
May 31, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
New freezer door required
I think this link will help you in finding the door for your model
Kuppersbusch door
SAM ANDERSON
Oct 06, 2008 | Refrigerators
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
