Dragon Naturally Speaking V8 Medical
I am running a Dell XP Dual Core with DNSV8 Medical. Recently, the program has stopped responding to the verbal command "check spelling", when it worked before. The second problem is that Dragon is repetitively inserting commas in sentences where they do not belong. This occurs even though I have turned off automatic insertion of commas and periods. I have this problem on two different computers and suspect it has to do with the user profile being corrupted but am not sure. I have tried varying the response time as well without success.
Gort007
  • 1187 Answers
SOURCE: I cannot save my user files in Dragon Naturally
Instead of "Save" files, use the "Save As" option.
Posted on Sep 30, 2009
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Apr 25, 2013 | Nuance Dragon Naturally Speaking 11 Home
I just bought naturakl speaking 11.5 home. how do i download it/
Dragon Naturally Speaking 11.5 FULL
If you already have a premium key,
Click here
Aug 29, 2012 | Nuance Dragon Naturally Speaking 11.5...
Dragon Naturaly speaking XP editions not finding audio and video cards
and we can assume your computer is running xp correct? If not, then you'll need the updated Dragon, naturally speaking
May 29, 2012 | Dragon Systems Nuance Dragon...
I installed dragon, I think but I can't find it. Can you help me
Under the Start menu. Or in Program Files on the C:\ drive, you can find the .exe to launch the program. Or do a search for the program.
Mar 11, 2011 | Nuance Dragon Naturally Speaking 11 Home
MY DRAGON NATURALLY SPEAKING 10-PROFESSIONAL DOES NOT WORK IN AOL EMAIL. IT WORKS WITH EVERY OTHER PROGRAM. BUT, WHEN I TRY TO DICTATE IN AOL EMAIL, NOTHING HAPPENS. ANYONE KNOW OF A SOLUTION?
Dragon Naturally Speaking 10 has not been tested to work with web based e-mail. It's also the same thing with Dragon Naturally Speaking 11 regardless of any version. As a work around and fix for this, if you want to use it through on any web based e-mail is to use the Dictation box.
Here are the simple steps to access the Dictation box:
1.Make sure you have successfully loaded a working user profile. 2.On the dragon bar, go to tools and then go to "Dictation Box" 3.Here, you can start dictating e-mail messages and use the "Transfer" button to transfer text in AOL E-mail.
I hope this solves your current problem.
Jun 05, 2010 | NRS Nuance Dragon Naturally Speaking 10...
Computers & Internet Logo
23 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
