Question about Car Audio & Video
How to block or scramble a gps tracker
Do you have any simple ways to block or scramble a gps tracker in a van.
  • adiemodo Oct 30, 2008
    i think my boss had fitted a tracker i dont mind being tracked i have nothing to hide it just would of been nice if he said .want to block it to make him own up to it being block.only want a temp block
  • ctrod Nov 07, 2008
    a local gang has a tracker on my vehical. they have been following me around. I have confirmed the transmission with a low grade rf detector. Its somewhere on the passenger side front. I have filed a police report but i cant find anyone in town who can remove this device.
    Can anyone help me...
    I am partially disabled and probably in danger, only my realationship with God has kept me.
    my email is christianthought@gmail.com
    if you know of a method or a product that really works
  • 17 Answers
Before I answer this I would have to know why you are trying to be elusive. Did you steal the van? Are you planning to? Are you going to drive it some place you dont want to be discovered?
GPS trackers are used for a reason. I dont want to help you disable it without first knowing why...
Posted on Oct 07, 2008
  • crnext Jan 07, 2009
    ctrod:
    I would recommend possibly trading the car in the next town, or the
    next state. What is to stop the gang members from placing one on your next car? You have to admit that this sounds a little far fetched. GPS trackers are not cheap! The cheapest I have seen to date is around $150. I can't say that any gang members would spend that kind of money to track you.
    adiemodo: You will first have to locate the antenna of the device. It most likely requires a direct view of the sky at all times. (catch my drift?) Obtain some heavy copper foil and wrinkle it up. Make sure it is grounded with common ground of the automobile... WRAP THE ANTENNA with the copper foil.
    Of course, you can always disconnect the antenna. It SURELY has a connector to facilitate removal for service/installation purposes.
    DISCLAIMER:
    The information provided by me, myself, or I,(hereafter known as provider or providers) is only intended to be
    general summary information to the public. It is not intended to take
    the place of either the written law or regulations. Any action or procedure performed is done at the sole risk of the user. The provider(s) of the preceding information cannot and will not be held accountable for any violation of law, damage to property(ies), or personal dangers, or other inflicted harm. The provider(s) of this information strongly urge every recipient to seek professional assistance with the issues before attempting any of the suggestions or proceedures provided herein. In short: Provider(s) does (do) not recommend doing this yourself. GET HELP.
Ihave a tracker in my works vehicle can i block the signal
U have to break it to block signal so dnt try. Where u wnt to go in work tym go with another vehicle
Jan 08, 2012 | Navman GPS4410 GPS Receiver
I have started work for a company they have fitted a tracker device could you tell me how to temporarily disable it as i want to go to heathrow airport to pick my mam and dad up we cant use van for...
The only way is on Sim type trackers - remove the sim or tracker but some trackers are a micro - implant hidden anywhere on the car, you would need a bug searcher .. .. .. to be honest all too much hassle. Just be honest and ask to borrow the car.
Dec 07, 2010 | 2010 Volkswagen Jetta
Tracker 5600 cant see display worked fine last week
Last fishing trip was at night and due to the brilliance of the display my son turnred it down and unknown to me actually turned it off ( the backlight) and it was only after trying everything else found it was the simple solution of turning it (the backlight) back on. oops
Jan 05, 2010 | Navman Tracker 5600 GPS Receiver
Company just had navman tracker fitted to van, how do i switch or disconect it?
This will depend on a lot of things regarding how it was installed. However, the most likely and easiest way that will probably work is to look for the power supply. If it's just mounted on the dash or something, it will probably be a simple case o pulling out the plug. Of course, it's far more likely that it's attached to the cars power supply proper. So, pop the bonnet, and have a look around. Check close to the battery (lazy mans intallation) or close to the vans electronics equipment, which on a car is usually near the firewall. Somewhere there, you should be able to see either the tracker or it's power connection, which will look different to the Vans power work (if not just newer). Then, it should be a simple case of pulling it out at one end or somewhere in the middle. Of course, fiddling with your vans power circuits is very dangerous, both for you and for the van. And if you do turn it off, it will be quite obvious to your company, too, so you should be careful. Of course, don't come back to me if you've broken it, your van or yourself. You asked the question, and I've never seen the thing, so be careful with what you do. Hope this helps.
Sep 25, 2009 | GPS
How do i locate my lost tomtom gps
If your meaning can you track the GPS, no you cannot track a GPS unless it has a tracker fitted, you cannot trace it if it has been stolen,
Ironically, they work in the opposite way to a tracker, it is a locater, not a tracker
Regards.
Jun 20, 2009 | Tomtom ONE GPS Receiver
Removing vehicle locator from my dodge caravan
An easier way is to get a gps jammer. They make nice ones for cheap. Check the import sites from china. They make a small unit that plugs into cig lighter socket, and is no bigger than your thumb.
http://tayx.manufacturer.globalsources.com/si/6008827809982/pdtl/Security-products/1006202554/Car-GPS-Tracker-Jammer.htm
or
http://www.google.com/search?hl=en&source=hp&q=china+Car+GPS+Tracker+Jammer&aq=f&oq=&aqi=
Apr 15, 2008 | Vehicle Parts & Accessories
Navman Tracker 5500 turns on but locks itself in the entry page
Have the same problem??
Used to take less than a minute to acquire satellites now takes 10-20minutes.
Nov 08, 2007 | Navman Tracker 5500i GPS Receiver
Car Audio & Video Logo
8,044 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
