Question about HP Office Equipment & Supplies
My printer is printing Ok but the face of the paper is very overprinted and dirty
  • toni482 Mar 28, 2009
    My page looks dirty and has a shadow of what I printed below it.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1- what printer???????????????????
2-what do you mean overprinted????????
I can only think of 2 things, drum cartridge and fuser
Posted on Oct 02, 2008
My Officejet 4500 does not eject a printed page fully, causing the next page to overprint the bottom of the previous page.
Sounds like the printer is set up to print a smaller size paper than the sheet size you are actually using. Measure your paper size, then go into the printer settings and choose the sheet size that matches.
Oct 20, 2014 | HP Officejet 4500 All-in-One Inkjet...
Image prints at the edge of the canvas
you should check the paper size loaded at the driver open devices and printers- choose HP DJ5500 driver - right click and open Printer properties-click the paper/sizes tab at the top-check that the paper size is set to ROLL- then set roll size ( 24"=A1--36"=A0---42"=A0/2A0)
now when you try to print make sure that the printing application ( EG paintshopPro) has the correct Page size (under document Properties)
and that your not strectching to fit or using the overprint commands within your printing application. the plotter should never be allowed to overprint as this model has no ay of clearing the excess ink that would be left on the platten
Dec 24, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
Lexmark X73 not pulling paper through properly, overprinting lines, part printing documents and printing some lines in colour shadowing the black print. I have used different grades of paper but still the...
Your printer's rollers sound like they are worn along the paper path. I suggest you taking your printer in to have a maintenance cleaning or have the rollers replaced. This will resolve your issues.
May 28, 2010 | Lexmark X73 All-In-One InkJet Printer
There is double printing or shadow-like printing with my HP 6313
change cartridge
the print head of our cartridge is damaged
Apr 26, 2010 | HP Officejet 6310 All-In-One InkJet...
Printer is printing double
Define "double".
Do you mean "bold" fonts, rather than "regular" fonts?
Do you mean not "advancing" the paper, line-by-line, and "overprinting"?
Do you mean "double-sided", rather than "single-sided" ?
Nov 29, 2009 | HP PSC 1510 All-In-One InkJet Printer
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Brother MFC-8840D print quality very faint and also overprinting same page three times along the page - please help!
refil teh ink, and open it up.. make sure you print 1 paper and see that it feeds properly. if it has a problem somewhere take actions to fix it... duct tape usually helps :P
Jul 29, 2009 | Brother MFC-8860DN Printer
I have a photosmart d5363. battle to print on a printable cd.how do i calibrate from working from media face. 762438@yebo.co.za
Part of the Neato software is a calibration function (It is on the installation disk)
You run it and it prints out a chart which tells you how far out your printer is
You then change some values on the setup to suit the mechanics of your printer and it should be in line
I use Neato and find that even with a machine that is supposed to be lined up I get overprint
It is easier to make your layout then make a print on paper using a dark colour , lay this on top of a CD and see which way the machine drifts.
You can then drag the image around on the Neato scream to make sure that it is in the right place before you print a CD
Jun 04, 2009 | HP Office Equipment & Supplies
Xerox 8500 - overprinting when double-sided
That normally is caused by a dirty maintenance kit. Often times they dry out and do not put enough lubricant on the drum, I would start with a new mainteanace lit., you may also have a bad wiper blade, although thats less likely.
Apr 14, 2009 | Xerox Phaser 8500/DN Printer
Can't print custom paper size on HP Photosmart C6180
Printing anything other than 8.5" x 11" I have found challenging but there is a way around it. When you are ready to print select Print and go to
"Properties" button beside the name of the Printer.
Select normal for your print quality,
Paper source select Main Tray,
in resizing options select the size you need. In this case you would make a custom or perhaps the Card Envelope 4" x 6"
Select "Scale to paper size"
under the Resolution button there is a box "Show preview before printing" I select that so that I can see for sure before printing that it is recognizing my special paper and not the usual 8.5 x 11 sheet.
If it all looks good and it should, START PRINTING
You have to do this everytime you want to print a special size paper. If you print a lot of this size of paper custom name it something easy like your name"Krissy card env" so you can find it quickly and remember easily the process you follow.
Jan 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
57 people viewed this question
Seeker5211
Seeker5211
